Old 08-19-2015, 09:23 AM   #1
frssfo
frssfo's Avatar
Drives: 2015 FR-S
Tire Center Bar Wear Question
I was at Thunderhill last weekend, running the dunlop starpec 2s. I've been experimenting with tire pressures, starting at 35lbs and letting a little air out at a time. At 32lbs the tires feel most consistent to me. However, when I looked at the tires at the end of the day the center bar was worn in a slope towards the right side of the car. I suspect that this is normal, because the track is mostly left-hand corners, but I wanted to verify that this is normal, and not under-inflation.
If you've got some experience with tire wear at the track can you chime in?
Front Passenger
Rear Passenger
frssfo is offline   Reply With Quote
Old 08-19-2015, 09:25 AM   #2
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
If you start to see wear like that you can have the tires flipped. These tires are directional so you don't have too many options with rotating. I also use around the same PSI for mine and they tend to wear a bit more on the outside edges.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 08-19-2015, 12:36 PM   #3
More camber
Racecomp Engineering (08-19-2015)
Old 08-19-2015, 12:37 PM   #4
strat61caster
strat61caster's Avatar
How much camber are you running? Mine did the exact same as you describe when I went to laguna last winter, I was on -0.3 (I can't see your pics for whatever reason).
Even after 10k street miles, 7x AutoX's (~50 runs) and 2x track days (both Laguna 100 mins each) my ZII SS can still lay down a quick lap in the hands of a good driver.
ineedyourdiddly
Old 08-19-2015, 04:34 PM   #5
r0nd3L
Drives: 2015 FRS
My RE-71R looked similar, except one side of the center bar was almost down to nothing after two track days at Autobahn South. Stock suspension with -2.1* front camber, 0" toe, rear stock settings.
r0nd3L is offline   Reply With Quote
Old 08-19-2015, 05:17 PM   #6
DarkSunrise
DarkSunrise's Avatar
Same here with Nitto NT05. Stock suspension, -1.5 front camber, 0 toe.
2022 BRZ Build
2013 FR-S Build
Old 08-19-2015, 07:12 PM   #7
DarkSunrise
Originally Posted by solidONE View Post
Are you guys limited in adjustment? Most of the 86's around here with alignment setup for track duty are running -3 or more degrees of front camber or the maximum allowed by their hardware. I managed to get -3 on my stock dampers using 2 sets of SPC bolts. Front tire temps across the tread were pretty good at the track and chasing my friend in the canyons while running 215 and 225 RS3s.
Interesting, I'd always heard the chance of slippage was much higher with camber bolts in both holes. Anyway -1.5 was all I could get with a single set of whiteline lobed bolts on the top hole.
I'm also getting pretty close to the struts with 235/40/17 tires on +42 offset wheels, so that's a concern as well.
2022 BRZ Build
2013 FR-S Build
Old 08-19-2015, 09:51 PM   #8
frssfo
frssfo's Avatar
Drives: 2015 FR-S
@CSG Mike - do you know anywhere that I can get a good suspension setup that would allow me to add more camber??
@strat61caster - I'm running 1.5 degrees of caster with the crash bolts and total toe is 0.7mm at the front. Rear camber is 1.8 degrees and total toe is 3.3mm.
It seems this will be normal until I can add more camber.
The Following User Says Thank You to frssfo For This Useful Post:
strat61caster (08-20-2015)
Old 08-20-2015, 12:05 AM   #9
Yes. PM me with what exactly your goals are, and your budget, and we'll see if there's anything that matches your goals.
Old 08-20-2015, 06:22 PM   #10
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
if it was worn out in the center I would suspect the tires were over inflated, when you say starting at 35 psi do you mean the target/hot pressures? otherwise it would be insane IMO , even for a lighter car like ours...
But in the picture where you're holding the level it looks like it wears from the outer/right side which may be normal with the lack of more negative camber (or vice versa if it's the inner side) + more left turns + over-inflated tires..
It may well be a combination of those factors but hard to say which contributes more
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
solidONE (08-20-2015)
Old 08-20-2015, 06:56 PM   #11
glamcem
glamcem's Avatar
maybe @rice_classic can chime in and spot more lights on that since he changes his alignment between sessions during the race
Old 08-20-2015, 08:16 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Yes sir! Sometimes I change my alignment during the race! The last time that happened I had 45 degrees of positive camber!
To the OP: The tread pattern is directional, not the rubber nor the carcass (very few exceptions to this). So long as the track is dry (no standing water needs to be displaced) then you can run them in whatever direction you please and considering your wear, you should consider this. Just rotate them back on your drive home... in case it rains.
If, for some reason you're weird about tread direction, then you can rotate the tire on the wheel before rotating the wheels, but unless you own a tire machine, this gets pricey.
OP should do this.
if it was worn out in the center I would suspect the tires were over inflated...
But in the picture where you're holding the level...
I hope the level was just for purposes of illustration but yeah weird wear patterns can show up when a tire is under or over inflated. The Toyo R888 was famous for it's "groove of death" that looked similar to this albeit much more pronounced.
However, I don't think that's what's happening here. It looks like you just have accentuated wear on one side which is to be expected and the "groove" is more of a factor of the tread squirm under cornering loads.
32 hot is probably on the low side while 35 cold would put on the high side. Aim for 35-40 hot.
Another option: have a friend ready with one of these right as you come off track and check inside/middle/outside temps.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
glamcem (08-21-2015), strat61caster (08-20-2015)
Old 08-20-2015, 09:58 PM   #13
frssfo
frssfo's Avatar
Drives: 2015 FR-S
Mike already has a deposit from me for the CSG Unicorn Suspension so I'm just yanking his chain.
I started out trying 35psi hot (measuring the tire pressure at the end of a session) and then lowered the hot pressure 1lb at a time each session until I got to 32lb hot. At 35lb hot the tires seemed to get "greasy" and I was sliding around after a few laps. Not so much with the lower hot pressure.
I have been switching the front and back tires on the same side after each track day. I'll move them to the opposite side of the car next time I'm at the track and see how that goes.
I trailer the car to and from the track - so no worries there
OP should do this.
Oh, I did this a long time ago. Mike told me I drive like an old granny and I don't need suspension until I start breaking the 50mph barrier
I have one of those, but no friends. I've been trying to remember to use my one of these instead:
Old 08-21-2015, 12:52 AM   #14
rice_classic
That fancy adapter for the iphone isn't the droid you're looking for (no phone pun intended). Just like an infrared gun, it's only going to show you surface temp but what you want is the temp about 1/8' or so inside to actually measure the temperature of the tread band. And worse, if you aren't getting a reading immediately coming off, you're not getting accurate data anyway.
PRO86 | WTCC | STL
Tire Wear question bacon_cheese_beer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 12-08-2014 02:51 AM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
Odd rear tire wear...anyone else? BRZnut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-09-2014 07:31 PM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-14-2014 11:35 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 09:50 PM
