Drives: 2013 FRS
Quick offset question
Hi guys
Looking at getting some Works D9R 18" rims The shop has 8.5 +38 front and 9.5 +38 rear. I usually see people with a larger offset on the rear when they do staggered. Does having he same offset make sense in this case (staggered setup)? Just wondering if it'll look weird. Thanks a million for your advice all
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
Hey James, that should be a pretty good fit for the FRS. It's not a super aggressive setup but pretty sporty for the FRS / BRZ
#3 | |
Bannéd
Drives: 2013 DGM BRZ
I have the BBS CH-R 18x8 +38 and at stock height they perfectly ride the line between poke in the front and tuck in the rear. It really all depends on how low you go and what amount of camber. I dropped about 2.75 inches, and the front sits just about flush, but the rears tucked in about 22mm due to my aggressive camber setup for AutoX. For everyday street use, I have Perrin 25mm spacers in the rear, and it gives it a perfect profile IMO. Really depends on the rest of the setup, but if you are running between stock height and -1" you should be golden. For reference, the pic shows how it sat before adding any significant camber or the rear spacers.
The fascinating thing about my signature is that by the time you realize that it is of no importance, it will also be too late to stop reading it. Good luck getting those five seconds of your life back. |
#4 | |
Bannéd
Thank you good people of BPAuto!
Picked them up off of member bobsacamenoh for too good a deal to pass up. They weren't quite the style I was originally planning on, but as soon as I mounted them I fell in love.
#6 | |
| Question on offset | FRStrent | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-18-2015 08:21 AM |
| Quick Offset Question | Dezoris | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-19-2014 12:31 AM |
| Quick question?!?! | tr1x5tuh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 01-18-2014 02:55 PM |
| A Quick Question! | emerald_ir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-18-2014 07:43 AM |
| Quick vid of new Nameless Offset revised system | GTB/ZR-1 | Engine, Exhaust, Transmission | 35 | 02-07-2013 07:02 PM |
