Old 02-17-2015, 12:21 PM   #1
FRStrent
Drives: Scion FRS
Question on offset
So my car is an hour away in storage and don't have time to go look at it. The wheels I want to get are a +20 offset. The stock offset on the stock wheels is +48. So, 48 - 20 = 28. 28mm difference. 28mm = 1.1 inches. So the wheel will be sticking out 1.1 inches more than stock. My question is, will the wheel be sticking outside the body of the car? because I'm not sure how I feel about that. If I could get to my car I would just measure it but I can't.
Thank you.
FRStrent is offline   Reply With Quote
Old 02-17-2015, 01:02 PM   #2
FRStrent
Drives: Scion FRS
nvm changed my mind lol
Old 02-17-2015, 01:12 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Offset needs to be considered in context of wheel width.
A number you should memorize is 41. That is the number of mm the face of the wheel is from the backpad, aka how much off the brake rotor surface your stock wheels sit.
To figure out how much a wheel will stick out, you'd need to know only wheel width and wheel offset. So a +20 on a, say, 8.5" wheel will be (8.5/2*25.4) - 20 = 87.95mm out from rotor surface, which means it will be 87.95-41 = 46.95mm (1.85") farther out than your stock wheels.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
FRStrent (02-18-2015), guslucatero (02-17-2015), RFB (02-18-2015)
Old 02-18-2015, 08:21 AM   #4
FRStrent
Drives: Scion FRS
Thank you for that information. Much appreciated.
offset help mikltov Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-27-2014 03:40 AM
Quick Offset Question Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-19-2014 12:31 AM
205/55 16. 40 offset. Will they fit? Nourdmrolnmt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-02-2013 01:31 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
Offset for GT vs. GTS giraffee AUSTRALIA 3 07-20-2012 12:30 AM
