Old 08-18-2015, 05:40 PM   #1
Allang402
Drives: Scion FR-S
FR-S won't rev past 4k
Hey guys. I'm having some issues with my car.. I let the car warm up for 10 mins, started driving in the highway, and nothing. It won't allow me to go past 4000 rpm. No CEL. No aftermarket parts.. And worst of all, no warranty. I've disconnected the negative terminal. Hopefully resetting the ecu will help.. Any/ all suggestions would be helpful.
Allang402 is offline   Reply With Quote
Old 08-18-2015, 05:42 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Manual or Automatic?
jawn is offline   Reply With Quote
Old 08-18-2015, 05:44 PM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Could be a bad cat? I think i remember reading a thread a while back where a guy had the same issue and it ended up being his front cat has disintegrated and was plugging up his exhaust.
Good luck!
Freeman is offline   Reply With Quote
Old 08-18-2015, 05:54 PM   #4
steve99
as per above post could be exhaust blockage caused by cat failure.
did you connect obd scanner and scan for codes not all codes cause cel light.
ecu in limp home mode limits rpm to arround 4000, but you would expect a cel light.
Old 08-18-2015, 06:21 PM   #5
Allang402
Drives: Scion FR-S
It's a manual.
Old 08-18-2015, 06:23 PM   #6
Allang402
Drives: Scion FR-S
Good luck!
I'll definitely check this. But but I did scan it with the ms300. No codes. No lights.
Old 08-18-2015, 06:31 PM   #7
Allang402
Drives: Scion FR-S
So guys, I had disconnected the negative terminal. It has seemed to fixed it? But I'm still worried. Any ideas what it may have been other than the cats/exhaust?
Old 08-18-2015, 06:32 PM   #8
Freeman
Freeman's Avatar
Edit. Nvm
Old 08-18-2015, 06:32 PM   #9
Allang402
Drives: Scion FR-S
Btw, I've been having the idle dip problem.
Old 08-18-2015, 06:48 PM   #10
CARBONGT86
CARBONGT86's Avatar
Drives: 13 carbon accents Blk
Try setting the Rev limiter look on you tube how too. My idle dip came back on my 2013 brz and the dealer updated the ECU.
CARBONGT86 is offline   Reply With Quote
Old 08-18-2015, 07:04 PM   #11
steve99
sounds like it was in limp home mode.
very strange you found no codes or no cel light.
assumed you scanned for codes before battery terminal removal, as resetting ecu clears all codes.
check battery volts and earth connections.
chas3wba0 (08-18-2015)
Old 08-19-2015, 12:15 AM   #12
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
my 2 cents. it is in limp mode. any chance you have an obd2 scanner and torque app? If you log into torque before starting the car, the car will go into limp mode only allowing you to rev to 4k and.... turning off the AC (wonderful on a 95 degree day). I however, got a cel in this situation.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 08-20-2015, 07:33 PM   #13
Allang402
Drives: Scion FR-S
I scanned a second time it gave me the code P0302. Cylinder misfire.. Where do I start on finding a solution?
Old 08-20-2015, 07:41 PM   #14
SkiRideDrive
Drives: 2015 FRS
Coil pack failed?
cant go past page 358 xITSxTHExPOPEx Off-Topic Lounge [WARNING: NO POLITICS] 31 07-10-2014 01:02 PM
My past Suzuki Samurai skye67 Other Vehicles & General Automotive Discussions 1 07-05-2014 12:27 PM
Engine sound past 4k rpm rainmonkey Engine, Exhaust, Transmission 13 05-24-2014 08:51 PM
Why NA? Because it might be a thing of the past.. rice_classic Other Vehicles & General Automotive Discussions 20 10-07-2013 09:06 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
