Old 08-17-2015, 03:29 PM   #1
Suparu
Drives: 2013 BRZ Limited
changing interior illumination from red to blue?
I'd been wishing there was some way to change the illumination from red to blue without costing a fortune but had just assumed it probably wasn't doable... until I saw this YouTube video a while back.
[ame="https://www.youtube.com/watch?v=oykeMRR0iOE"]Subaru BRZ Blue Interior Conversion - YouTube[/ame]
What would it take to do something like that?
Suparu is offline   Reply With Quote
Old 08-17-2015, 03:51 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just swap the LED's ?? They are cheap and it is not super hard to do. There is a DIY on here somewhere .
Old 08-17-2015, 03:54 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=58207
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
Suparu (08-18-2015)
Old 08-18-2015, 12:41 AM   #4
Jake_86
Jake_86's Avatar
Under $100 but countless man hours
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 08-18-2015, 08:03 AM   #5
Suparu
Thanks for the link. I've swapped gauge faces before so I remember how tricky it was to pull the tach/speedo/etc needles off then try to put them back on.
There's still the center console which I thought might be tricky to swap the LED's because I have climate control, but I found a post for that: http://www.ft86club.com/forums/showthread.php?p=1959880
I'm probably going to pull the plug on the idea of converting the LED's from red to blue because it just dawned on me that the interior stitching is all red. I'd have to swap out all those bits for identical pieces with blue stitching like the Series.Blue trim to match the blue LED's.
Old 08-21-2015, 07:01 PM   #6
johnbradshow
Drives: Audi
I know you can also change all the interior dome lights to whatever color for under $50.
johnbradshow is offline   Reply With Quote
Interior illumination Kit KevinYeh BRZ First-Gen (2012+) — General Topics 17 01-22-2015 09:43 PM
Interior Illumination Red/Blue Kit. qqzj Cosmetic Modification (Interior/Exterior/Lighting) 15 03-31-2014 01:07 PM
How to disable BRZ Blue Interior Illumination kit? tobin Electronics | Audio | NAV | Infotainment 3 02-17-2014 05:27 PM
changing interior LEDs jthornton1993 Cosmetic Modification (Interior/Exterior/Lighting) 4 06-14-2013 08:27 AM
interior illumination kit and side window visor davey90 AUSTRALIA 40 05-07-2013 09:49 AM
