Drives: 2013 Subaru BRZ Limited (Black)
How to achieve nice exhaust note in cabin?
Hello all--
After deleting the sound tube I have noticed a lack of exhaust/engine noise in the cabin. I'd like to modify/add to my exhaust setup in order to gain back some of the noise lost to the sound tube (which sounds very artificial IMO). I would like to do this without making things overly loud outside the car. Does anyone have any thoughts/ideas on how I can achieve this? I'd like to get a similar volume level to the sound tube (maybe more?), while avoiding drone for highway cruising. I'm interested in my own driving pleasure, and am not out to please/terrify neighbors or others on the street. I've currently got the Gruppes/Tomei UEL header installed with the stock OP/FP/Catback. I've also sound-deadened the entire car, including trunk (which I understand will help with catback drone). Thanks all!
Drives: 2013 Firestorm FRS
buy an op, fp or catback?
catback for sure- don't waste time with an OP/FP if N/A.
mild exhaust setups are aplenty, along with their reviews
Thanks -- What sort of ratio would you say adding on an OP, FP, or CB creates inside/outside the car? If I double the volume on the outside, will I notice it in the cabin? or?
I suppose what I really need to do is find some GT86 owners in my area and demo these things myself. |
#5 | |
At the same time, I know louder catbacks can be heard inside the car, but with very loud results outside. |
remember that you have a header up front- the muffling is very much at the backend of the car now. Try and find a friend or member on here around you with a similar setup is my only suggestion, as videos don't translate well- especially inside the cabin!
the FP cat is a minimal contributor in terms of noise reduction. |
Junior
Drives: a car
omg Koa is alive
Drives: '13 10 Series FRS #1203
Route the exhaust into the trunk space
Sarcastic SOB
Play a recording of a Ferrari Enzo with the volume at 50%.
Seriously., do your research and lose the stock cat back.
#10 |
Drives: Subaru BRZ
I found the standard sound rather flat and dull, changed to the following looking for the flat four burble with some character through the rev range ...Tomei Expreme UnEqual Length Exhaust Manifold, Milltek overpipe and Berk front pipe with high flow cat. The remainder is stock UK spec exhaust. The sound is great, got the flat four burble but it's very quiet when cruising.
#11 |
Lurker
Drives: '14 BRZ Ltd 6MT
I have a catless Ark front pipe with Helmholtz resonator. Kills a lot of the drone while adding a tiny bit of noise.
Instagram : @brampbell_candon Facebook : Hipster Vision Photography |
#12 |
Señor Member
A set up similar to this should give you a decent in cabin exhaust note...
#13 |
Señor Member
OP, if you want the car to stay relatively quiet maybe an intake will suit you better. Or even just a high flow filter, silicon tube and removing the rest of the resonators. During cruise the car will be quiet as stock but under acceleration the induction noise will be louder and more noticeable.
1974 TA22 Celica
2013 86 GT |
#14 | |
| Exhaust too louder in the cabin | Junkwipe | Engine, Exhaust, Transmission | 19 | 06-14-2014 01:16 PM |
| exhaust note, what are the factors? | BRZPDX | Engine, Exhaust, Transmission | 6 | 01-04-2014 09:04 PM |
| Nice cat-back exhaust! | Chad | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 08-29-2012 02:55 PM |
| Name that exhaust note | Rampage | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 04-14-2012 05:52 AM |
