BAE
Drives: Asphalt FRS
Air/Fuel Ratio for Stock FRS @ High RPM
Trying to educate myself on this topic. Just purchased a AF gauge and will be looking into getting a tune soon.
My question... Does anyone know the AF ratio at high rpm for our cars? What's the best ratio for power at high rpm? I've read a bit and it seems like every car is different. Thanks for helping. |
Drives: GT86-ACE-JRZ-RPF1-Essex
There is no real answer, AFR change all the time for each RPM and Load. It should be 14,7 most of the time.
It will go lower with load/RPM increase. You want to stay as close as possible to 14,7 as long as you got no detonation or overheating exhaust valves. Then your tuner will decrease AFR just enough to protect the engine. You don't want the lowest possible AFR, because you will loose at lot of gas and quite a bit of power.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#3 | |
most aftermarket tunersnaturally aspirated will target mid to high 11 afr at upper rpm.. Stock tune Primary oen loop fueling table |
| The Following User Says Thank You to steve99 For This Useful Post: | Decimus (08-11-2015) |
Resident Gear Head
WOT high RPMs should be 12.5:1 on regular gas for optimum performance 14.7 is incorrect and will be too lean.
14.7 for cruising. This is recommended for NA application.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following 3 Users Say Thank You to celek For This Useful Post: |
#6 | |
| The Following User Says Thank You to MaximeT For This Useful Post: | Decimus (08-11-2015) |
#7 | ||
BAE
Drives: Asphalt FRS
At WOT above 7k I hit 10.2 and I thought that was really rich. I'm going to ask if they can keep AF ratio between the suggested 11-12. Thanks for the replies! |
Drives: White 2014 BRZ
The OFT stage 2 UEL tune seems to run rich at least mine does and I'm at sea level. Its low 11's. I'm sure I'm losing a bit of power.
Resident Gear Head
Yeah but he was talking about high RPM so I figured I would specify. I don't know about you but I dont hover at partial throttle and 6000-7000 RPM
| The Following User Says Thank You to celek For This Useful Post: | theneptune86 (05-19-2021) |
#10 | |
![]() But I have seen many post (around here) and video where people drive crazy part load road driving rpm. Like JF on Drive TV. Anyway, sorry, I'm off topic :p
#11 |
#12 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#13 |
Drives: car
The AFR is that rich under high speed and heavy load to keep the cat from experiencing accelerated aging. It's to comply with EPA longevity requirements.
It's not a big deal if you do. It won't hurt anything although I would change my oil more frequently if that's something that happens regularly. |
#14 |
Drives: DGM BRZ Limited
I'm partial throttle at high rpm all the time. Do you guys every see the track? Not to say it's a regular occurrence, but every time I'm in a canyon or on the track the engine sees a lot of partial throttle high rpm. Especially when I'm sideways.
| The Following User Says Thank You to Coheed For This Useful Post: | theneptune86 (05-19-2021) |
| high octane fuel + FI, tune not needed? | BRZPDX | Forced Induction | 6 | 09-30-2014 12:41 AM |
| FBM Billet High Flow Fuel Rails | FullBlown | Forced Induction | 17 | 05-17-2014 02:53 PM |
| SOLD : AEM 30-4100 UEGO Wideband Controller Gauge - Air-Fuel Ratio | KSpider | Engine, Exhaust, Bolt-Ons | 0 | 04-11-2014 12:13 PM |
| AEM High Flow In-Tank Fuel Pump | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 04-13-2013 12:15 PM |
| Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
