Old 08-11-2015, 03:42 AM   #1
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Air/Fuel Ratio for Stock FRS @ High RPM
Trying to educate myself on this topic. Just purchased a AF gauge and will be looking into getting a tune soon.
My question... Does anyone know the AF ratio at high rpm for our cars?
What's the best ratio for power at high rpm?
I've read a bit and it seems like every car is different. Thanks for helping.
Decimus is offline   Reply With Quote
Old 08-11-2015, 04:52 AM   #2
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
There is no real answer, AFR change all the time for each RPM and Load. It should be 14,7 most of the time.
It will go lower with load/RPM increase.
You want to stay as close as possible to 14,7 as long as you got no detonation or overheating exhaust valves.
Then your tuner will decrease AFR just enough to protect the engine. You don't want the lowest possible AFR, because you will loose at lot of gas and quite a bit of power.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
The Following 2 Users Say Thank You to MaximeT For This Useful Post:
BAOVAN (01-16-2017), Decimus (08-11-2015)
Old 08-11-2015, 08:06 AM   #3
steve99
Drives: FT86
The stock tune runs quite rich at high rpm getting down to 10.7 afr.
most aftermarket tunersnaturally aspirated will target mid to high 11 afr at upper rpm..
Stock tune Primary oen loop fueling table
Old 08-11-2015, 09:40 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
.... but is that windows 98??
Old 08-11-2015, 11:33 AM   #5
celek
Resident Gear Head
celek's Avatar
WOT high RPMs should be 12.5:1 on regular gas for optimum performance 14.7 is incorrect and will be too lean.
14.7 for cruising.
This is recommended for NA application.
celek is offline   Reply With Quote
The Following 3 Users Say Thank You to celek For This Useful Post:
Decimus (08-11-2015), MaximeT (08-11-2015), zc06_kisstherain (06-06-2017)
Old 08-11-2015, 12:11 PM   #6
MaximeT
MaximeT's Avatar
14.7 for cruising.
I was not suggesting 14,7 for WOT
The Following User Says Thank You to MaximeT For This Useful Post:
Old 08-11-2015, 12:34 PM   #7
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Perfect chart. Yes idle was was sitting at around 14.7.
At WOT above 7k I hit 10.2 and I thought that was really rich.
I'm going to ask if they can keep AF ratio between the suggested 11-12. Thanks for the replies!
Old 08-11-2015, 01:09 PM   #8
stevo585
Drives: White 2014 BRZ
The OFT stage 2 UEL tune seems to run rich at least mine does and I'm at sea level. Its low 11's. I'm sure I'm losing a bit of power.
stevo585 is offline   Reply With Quote
Old 08-11-2015, 04:05 PM   #9
celek
Resident Gear Head
celek's Avatar
Yeah but he was talking about high RPM so I figured I would specify. I don't know about you but I dont hover at partial throttle and 6000-7000 RPM
The Following User Says Thank You to celek For This Useful Post:
theneptune86 (05-19-2021)
Old 08-11-2015, 04:17 PM   #10
MaximeT
MaximeT's Avatar
Looking at the journalists video on YouTube, they do that all the time. Which is of course stupid
But I have seen many post (around here) and video where people drive crazy part load road driving rpm. Like JF on Drive TV.
Anyway, sorry, I'm off topic :p
Old 08-11-2015, 07:08 PM   #11
steve99
Drives: FT86
nope XP running cut down theme so it runs better on my old netbook
Old 08-12-2015, 09:45 AM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Ahh! I see haha!!
Old 08-13-2015, 12:27 AM   #13
arghx7
Drives: car
The AFR is that rich under high speed and heavy load to keep the cat from experiencing accelerated aging. It's to comply with EPA longevity requirements.
It's not a big deal if you do. It won't hurt anything although I would change my oil more frequently if that's something that happens regularly.
Old 08-14-2015, 01:43 AM   #14
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I'm partial throttle at high rpm all the time. Do you guys every see the track? Not to say it's a regular occurrence, but every time I'm in a canyon or on the track the engine sees a lot of partial throttle high rpm. Especially when I'm sideways.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
high octane fuel + FI, tune not needed? BRZPDX Forced Induction 6 09-30-2014 12:41 AM
FBM Billet High Flow Fuel Rails FullBlown Forced Induction 17 05-17-2014 02:53 PM
SOLD : AEM 30-4100 UEGO Wideband Controller Gauge - Air-Fuel Ratio KSpider Engine, Exhaust, Bolt-Ons 0 04-11-2014 12:13 PM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
