Old 08-05-2015, 11:20 PM   #1
timmydatooth
Drives: Scion Frs
TRD Spring vs RCE Yellow Springs
Hey guys stuck between these 2 springs. So here are a few of my questions.
1) Which one has a lesser drop? will be using for daily driving so don't really want something too low.
2) Which will be better for my stock struts in the long run?
3) Which gives better handling and performance and will still keep a comfortable ride?
Thanks everyone and pics of these springs on your car will be highly appreciated!
timmydatooth is offline   Reply With Quote
Old 08-06-2015, 02:16 AM   #2
ort895
ort895's Avatar
Im pretty sure the TRD springs have a 1 inch drop.
And the US TRD springs are pretty much re branded Eibach springs, or at least that's what i've read.
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
The Following User Says Thank You to ort895 For This Useful Post:
SkAsphalt (08-07-2015)
Old 08-06-2015, 11:15 PM   #3
timmydatooth
Drives: Scion Frs
1 inch sounds good. do you know if the RCE yellows is less than that?
Old 08-06-2015, 11:24 PM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
It's posted right on the product page that it's a 20mm drop, which is less than the TRD springs.
drewbot is offline   Reply With Quote
Old 08-06-2015, 11:42 PM   #5
DAEMANO
Time Traveller
Like mentioned above. TRD Springs are essentially re-branded Eibach Pro-Kit. So it's Eibach Pro-kit vs RaceComp Yellow.
RaceComp Yellow
F - 0.8" drop - 4.5k rate
R - 0.8" drop - 4.5k rate
Eibach Pro-Kit/TRD Springs
F - 1.0" drop - 3.6k rate
R - 1.0" drop - 4.9k rate
RaceComp Yellow
Old 08-07-2015, 08:45 AM   #6
timmydatooth
Drives: Scion Frs
Ok so the racecomp yellows would be better for my daily driving since its a lesser drop. What does the 4.5k rate mean? Also will these lowering springs be ok on my stock struts? I hear a lot of people have trouble with that when they lower there car
Old 08-07-2015, 08:49 AM   #7
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
4.5k means 4.5 kilograms of "force" is required to make the spring shrink by 1 millimeter.
If you read the RCE Yellow description, the springs were designed for use with stock struts.
FYI I've been running the RCE Yellows for about 25,000 km.
The Following 3 Users Say Thank You to drewbot For This Useful Post:
Busybee (04-17-2020), Clipdat (08-07-2015), Racecomp Engineering (08-07-2015)
Old 08-07-2015, 09:33 AM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
I ran RCE Yellows for about 25000 kms as well. I just recently upgraded to their Tarmac 0 coilovers. I was very happy with the RCE Yellows, I think they're a perfect match for the stock dampers / suspension geometry. I was worried the front would feel too stiff, but it didn't at all. The only reason I wanted to upgrade was I found the stock dampers to be lacking, I strongly considered using Bilstein B6s, but I liked Yellows so much I decided to stay with the same suspension company.
The Following 3 Users Say Thank You to Calum For This Useful Post:
Clipdat (08-07-2015), Racecomp Engineering (08-07-2015), TofuJoe (04-08-2017)
Old 08-07-2015, 10:31 AM   #9
perryair
junior mafia
Drives: ‘20 sti limited
I'm running prokits now and the drop looks perfect to me, though as a few threads about them have said, it's probably closer to a 7/8 inch drop. the ride and handling are still great but you definitely feel bumps and road imperfections a bit more than with stock.
also, for whatever it might be worth the prokits/trr are black so less noticeable and also because they install them on frs as a factory option whatever minute chance that dealers might be a little more warranty friendly in case of a suspension issue in the future it seemed like the ever slightly safer choice.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
The Following User Says Thank You to perryair For This Useful Post:
kuno (05-05-2017)
Old 08-07-2015, 10:50 AM   #10
D_Thissen
D_Thissen's Avatar
I have had RCE yellows on my car for 6000km and have zero complaints so far. Combined with some front end camber, the car feels very well balanced and planted.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
Ammunition (07-14-2016), Racecomp Engineering (08-07-2015)
Old 08-07-2015, 10:57 AM   #11
Createddeleted
Drives: 2014 BRZ - 2004 GLI
I have the TRD springs on my BRZ and I don't like them as I feel I lost a lot of balance.
Createddeleted is offline   Reply With Quote
The Following User Says Thank You to Createddeleted For This Useful Post:
tobin (03-21-2019)
Old 08-07-2015, 11:09 AM   #12
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
This is because the TRD springs where meant to keep (and slightly improve upon) the handling characteristics of the FR-S while also giving you stiffer rates. Since the BRZ stock springs give a more neutral balance, as opposed to tuning towards more oversteer, you're definitely going to feel like the car has "lost balance." It hasn't really lost it, but it has changed the way that it's balanced. Just different strokes for different folks.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-07-2015, 11:23 AM   #13
timmydatooth
Drives: Scion Frs
Thats good to know! Do you have any problems going over speedbumbs or backing out of driveways? No scraping or things like that? Also do you feel any kind of performance or handling difference with these springs?
Old 08-07-2015, 11:25 AM   #14
timmydatooth
Drives: Scion Frs
I thought the trd springs were red? Thats why i was leaning a little more towards trd since there made by toyota and the warranty and all. Were the trd springs also designed to work with the stock struts?
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks Kyogre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-12-2015 04:59 PM
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
RCE Yellow spring kit, should I get the camber bolts? jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-20-2013 07:36 AM
