Old 07-30-2015, 04:57 PM   #1
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
Window making a loud "crack" noise - any ideas?
Problem just started recently. When my I lower my passenger window from a fully closed position, it makes a loud "crack" noise. This ONLY happens when it is hot. So in the morning and evening it's fine. But if I open the window when I get off work and the car is hot, the window will make the loud crack noise. Driver side is fine. I can't see the window catching on anything, although a small section of the rubber appears to be wearing, but shouldn't be making that noise. Any thoughts? I'm taking it to my mechanic for a regular service in a couple weeks, but I'm not sure if I can duplicate the problem if it's cool that day, and want to make sure I'm not damaging any thing.
edit: I did have the frozen power window fix done last year if that makes a difference
jermyzy is offline   Reply With Quote
Old 07-31-2015, 01:21 AM   #2
Poodles
Drives: 2015 Series.Blue
Lubricate the seals.
Old 08-05-2015, 06:52 PM   #3
jermyzy
Thanks, I'll give that a try. From what I've googled, silicone lube is the best choice?
Old 08-05-2015, 07:03 PM   #4
Tee hee Lube the seals
Yes silicone lube works well just use a very small amount though and refresh every month or so by wiping it down well and putting fresh on.
Old 08-05-2015, 07:07 PM   #5
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
Just started happening for me the other day too. Keep me posted, and I'll do the same.
Special_K is offline   Reply With Quote
Old 08-18-2015, 04:22 AM   #6
ayilar
Drives: BRZ, MB C350
Same here!
2013 BRZ Premium MT (lightning red)
2008 MB C350 PII (steel grey)
ayilar is offline   Reply With Quote
Old 08-24-2015, 02:42 AM   #7
jermyzy
Well I brought it to my mechanic for regular service. He couldn't find anything wrong and suggested using silicone lubricant for the seals, so he lubed it up and it's still making the noise...I applied a second coat of lube myself when I got home and still the same...any other suggestions? It's a pretty loud cracking noise when it's really hot...
Old 08-24-2015, 02:03 PM   #8
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
can you get someone else to operate the window so that you can try to pinpoint the source of the noise? you might need to use a mechanics stethoscope. One of my mechanic friends says this stuff is good, but it's kind of expensive.
[ame="http://www.amazon.com/Honda-Genuine-Shin-Etsu-Grease/dp/B006Z9TZ9M/ref=sr_1_3?ie=UTF8&qid=1440434975&sr=8-3&keywords=shin+etsu"]Amazon.com: Honda Genuine Shin-Etsu Grease: Automotive[/ame]
fx1mark is offline   Reply With Quote
Old 08-25-2015, 01:03 AM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
I glossed over this the first time around because I didn't want to get in an argument over the lube issue.
There are fore and aft hard stops the window lands on at the top. When one of them slips out of adjustment, the regulator binds up. That's the loud "clack" you hear. It's a bitch to get it aligned just right. I considered writing a DIY until I realized it's like trying to explain how to hang a door in 5 easy steps. It's more art than process. I'd offer to help but I live in the wrong Vancouver.
Old 08-25-2015, 01:07 AM   #10
Ultramaroon
not playing cards
Come up to my pad one of these days and I'll help you fix yours. I can't talk anyone through it. Way too much detail and finesse involved.
Old 08-25-2015, 12:33 PM   #11
Special_K
Bannéd
Special_K's Avatar
How about you come down to my pad? We can have a clutch/window day, and anything you want done! I have a lift now *nudge*nudge
...Mine hasn't been as bad since it started cooling off, but definitely isn't just a seal lube problem. I figured it must be the way it seated or tracked.
Old 08-25-2015, 12:52 PM   #12
bababooey
Drives: BRZ SWP Limited -6MT
my drivers door makes this noise. passenger is fine. mentioned to service dept at the dealer when getting oil change. they claimed to not find any difference between the two so they were of no help. ill look into the silicone grease though, hopefully alleviate the issue
Old 08-25-2015, 01:19 PM   #13
Ultramaroon
not playing cards
Oh, yeah, your lift! Hell yeah.
Old 08-25-2015, 01:32 PM   #14
There are a couple of different sources for this noise.
One is what Ultra is talking about and like he said it is a bitch to get just right. I made my dealer do it under warranty and it took them hours but they got it. (I also got the TSBs done as a bonus)
The other is the glass sticking to the rubber seal and then giving a load "pop" or "snap" noise when you bring it down. I had this as well and at first just used silicone to correct it. I noticed it again really bad a few days after I did a full wax on my car. It would be far worse when it was hot during the day and tapper off as it got cooler. This made me curious so instead of just slapping more silicone on I played around a bit and realized that when I waxed the car I got some on the window seals (it is a polymer wax and OK on plastic and rubber). What was happening was that when it was hot and the wax softened just a bit the glass would stick to it and give quite a pop when rolled down. Cleaned the seals and glass edges up with some alcohol (for both me and the car) and the problem went right away.
Collection of "Subaru axing BRZ" & "Subaru making next-gen BRZ" rumor threads... mav1178 Other Vehicles & General Automotive Discussions 42 07-07-2014 03:52 PM
"Washington State Troopers Crack Down on Left-Lane Squatters" glamcem Northwest 35 06-27-2014 11:45 PM
anyone making an FRS Front lip with "fang" delete??? sidnacious Cosmetic Modification (Interior/Exterior/Lighting) 33 01-31-2014 07:31 AM
Anybody making a tail light "T connector"? Trashed675 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-08-2013 08:44 AM
JDM "conversion" ideas jcutner Scion FR-S / Toyota 86 GT86 General Forum 27 03-17-2012 08:29 PM
