Old 04-05-2013, 04:47 PM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Anybody making a tail light "T connector"?
I am really wanting to add the triangle brake light, but i don't want to hack up or tap into my OEM wiring. I saw [ame="http://www.amazon.com/Curt-56035-CURT-Manufacturing-T-Connector/dp/B0021JKLAW/ref=sr_1_fkmr0_1?s=automotive&ie=UTF8&qid=13651922 93&sr=1-1-fkmr0&keywords=scion+frs+T+connector"]THIS [/ame] a couple days ago and thought that it should work for adding the brake light in. The trouble is, i haven't been able to find anyone that makes one specifically for the twins.
Anybody know of anything available or in the pipelines?
Trashed675 is offline   Reply With Quote
Old 04-05-2013, 05:38 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I tried to find the connector, but couldn't, otherwise I was actually going to try and put a kit together.
Old 04-05-2013, 06:12 PM   #3
Trashed675
Trashed675's Avatar
If you put a kit together, make sure you do a DIY for it. You'd get many thanks
Old 04-08-2013, 08:44 AM   #4
F n' A Automotive
F n' A Automotive's Avatar
Drives: 11 STi Sedan
Originally Posted by Trashed675 View Post
I am really wanting to add the triangle brake light, but i don't want to hack up or tap into my OEM wiring. I saw THIS a couple days ago and thought that it should work for adding the brake light in. The trouble is, i haven't been able to find anyone that makes one specifically for the twins.
We've tried finding the OEM connections to make a plug n play kit, but had no luck . The splice taps we provide with our kit simply pull off the OEM wire leaving just a sliver of exposed wire to be taped over if you ever wanted to go back to stock!
F n' A Automotive is offline   Reply With Quote
anyone making an FRS Front lip with "fang" delete??? sidnacious Cosmetic Modification (Interior/Exterior/Lighting) 33 01-31-2014 07:31 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
