Old 10-20-2013, 07:55 PM   #1
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Possible to remove headers without disconnecting frontpipe?
Hey guys, a kind of non exhaust-related question but this seems the right forum to ask.
I need to drop the headers to install a block heater, and can't figure out if I can remove the headers without taking out the midpipe to allow me to shift the overpipe back a bit to let the headers come off. Looks like the bolts in the overpipe may stop me bringing the headers down if it isn't moved back a bit.
Do I need to loosen the overpipe to let the headers drop? I'm trying to figure out how many gaskets I need to buy before installing the block heater.
Thanks
Jon
jonboy99 is offline   Reply With Quote
Old 10-20-2013, 10:45 PM   #2
mjsivee
Drives: Scion FR-S
I was able to leave the overpipe and front pipe on with no problem when I installed my Rev Works Headers. The biggest pain was loosening the secondary o2 sensor. Good Luck!!!
mjsivee is offline   Reply With Quote
Old 10-20-2013, 11:45 PM   #3
jonboy99
jonboy99's Avatar
Perfect, thanks. Shouldn't need to worry about the o2 sensors as I can just temporarily disconnect them at the other end I think.
Jon
Old 10-21-2013, 12:16 AM   #4
mjsivee
Drives: Scion FR-S
You will have to hold the bolt on the opposite side (with a wrench) while you loosen it on the other side off. And will just have to switch sides holding the bolt and screwing it off with the other bolt.
That might sound confusing but its pretty straightforward once you get underneath there.
Overpipe or frontpipe? feldy Engine, Exhaust, Transmission 8 09-10-2013 01:01 PM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
Disconnecting battery for installations i_4got Electronics | Audio | NAV | Infotainment 2 11-21-2012 01:04 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
CAT removal in the frontpipe, CEL? Areddi Engine, Exhaust, Transmission 5 08-18-2012 04:22 PM
