Old 04-06-2013, 10:48 AM   #1
bakerr6
Drives: 2013 raven black fr-s
centering rings necessary?
What are your takes on centering rings for aftermarket wheels? I've never used them (always had wheels that fit to a specific model) and am not sure if they are necessary. I'm going to be running motegi traklite wheels and I believe they may be necessary.
bakerr6 is offline   Reply With Quote
Old 04-06-2013, 06:30 PM   #2
bakerr6
oh well, I'm jsut going to install the hubcentric rings and not look back. looks like the bore on my current wheels are different than the hub
Old 04-06-2013, 06:35 PM   #3
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
never have used them, never had a problem. just torque correctly.
Jesse is offline   Reply With Quote
Old 04-07-2013, 04:57 AM   #4
Blue86
Drives: Sonic Blue 86GT Manual
100% you should use them
Blue86 is offline   Reply With Quote
Old 04-07-2013, 07:11 AM   #5
dacedace
Drives: Ultramarine 86 GTS
Makes putting the wheel on a lot easier. no reason not to use at least some plastic ones.
dacedace is offline   Reply With Quote
Old 04-07-2013, 07:20 AM   #6
grodenglaive
Drives: asphalt FR-S
+ they only cost $10
grodenglaive is offline   Reply With Quote
Old 04-07-2013, 07:59 AM   #7
JDMenrique
DEEEERP
JDMenrique's Avatar
if they are needed you should use em.
JDMenrique is offline   Reply With Quote
Old 04-07-2013, 08:15 AM   #8
bakerr6
yea I went ahead and just purchased a set. Better to be safe than sorry. Thanks
Old 04-07-2013, 09:44 AM   #9
#87
I usually post drunk
#87's Avatar
I bought a set and have been too lazy to put them on for the last 6 months. Hasn't been any problems with hard street driving. I got plastic this time in the hopes they are easier to get off when I switch wheels. Aluminum I had in the past would almost weld to the hub whether I used anti sieze or not, would have to take a hammer and screw driver and chisel them off.
#87 is offline   Reply With Quote
Old 04-07-2013, 10:32 AM   #10
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
You should talk with a professional like Tire Rack or Discount Tire. I bought some Enkei GTC01's and metal (aluminum) centering rings were used for correct hub fit. They snapped in place.
BRZfan is offline   Reply With Quote
Old 04-07-2013, 11:16 AM   #11
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Not matter what anyone says you DON'T NEED THEM!!!! They do nothing to hold the wheel onto the car!!!
However I DO run them in all of my wheels because it makes it way easier to swap out wheels and tires and they are also dirt cheap. They do, do a job, it's just a non essential one. On cars with no studs and lug bolts it's a little more important to run hub rungs becuase there are no studs to hold the wheel on during tire changes and stripping lug bolts is more likely.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
mfbmike (03-24-2014)
Old 04-07-2013, 11:23 AM   #12
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Right they put them there for our health?
Huehuecoyotl is offline   Reply With Quote
Old 04-07-2013, 11:32 AM   #13
BlaineWasHere
Grip>Drift
Drives: FRS
Yep, Vitamins B12, C and Potassium are plentiful in hub rings.
Old 04-07-2013, 11:40 AM   #14
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
However I DO run them in all of my wheels becuase it makes it way easier to swap out wheels and tires and they are also dirt cheap. They do, do a job, it's just a non essential one. On cars with no studs and lug bolts it's a little more important to run hub rungs because there are no studs to hold the wheel on during tire changes and stripping lug bolts is more likely.
+1
Centering rings are an installation guide tool and really nothing else. The lug nuts properly seated to the wheels is what truly centers them and holds the wheel to the hub from the clamping action between the two surfaces (spindle hub and wheel hub interaction.) The rings can also melt/distort from track use (wheels get hot with track use! Touch one after coming in from a track session...) so I don't even use them on my track set. For my daily sets I leave them on if they have them... no issue if they don't or they become cracked/brittle with age; properly installing the wheel and securing the lug nuts in sequence by hand before tightening and torquing is what properly centers the wheel.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
BlaineWasHere (04-07-2013)
Hubcentric Rings Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 57 06-08-2016 01:42 PM
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-05-2013 10:57 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
works kiwami hub rings? derka-derka AUSTRALIA 3 01-12-2013 07:52 PM
