Old 07-22-2015, 12:59 PM   #1
SikCee
Pretend Mechanic
Drives: '13 Raven FR-S M/T
OFT Idea
Hi All,
Just an idea, after I got the OFT I found mounting it more/less an issue and after looking at other peoples idea it just seem like it was in the way.
So the idea is to have a setting/mode created to reverse the image and use the OFT as a HUD and place a reflective film on the windscreen. eg.
Not my image, just a quick google search.
J
SikCee is offline   Reply With Quote
Old 07-22-2015, 01:17 PM   #2
SlammedSilly
Drives: 2015 Ultramarine FR-S
ive noticed, that mounting the OFT is kinda a pain in the a**, like the idea a lot, maybe someone will go through with it!
SlammedSilly is offline   Reply With Quote
Old 07-22-2015, 01:41 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Nice idea if the OFT was a display-only item. The problem is that you often need to touch the screen to change modes/channels/datalog/etc,. An on-top-of-dash placement would make that difficult.
Old 07-22-2015, 01:45 PM   #4
JS + BRZ
Drives: 2010 MS3
Any plan on upgrading the device to something like Cobb Accessport device?
JS + BRZ is offline   Reply With Quote
The Following User Says Thank You to JS + BRZ For This Useful Post:
raven1231 (07-22-2015)
Old 07-22-2015, 01:50 PM   #5
Shiv@Openflash
Drives: 2013 FRS
Specifically?
Old 07-22-2015, 02:01 PM   #6
SikCee
Pretend Mechanic
Would it be possible to have the display settings saved so that when you start the car you can press a button and it will load your pre-set gauges and flip the screen?
Old 07-22-2015, 02:03 PM   #7
Shiv@Openflash
Drives: 2013 FRS
I don't see why not. If someone can test the viability of windshield reflection display, we can work on this.
Cheers,
shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
SlammedSilly (07-22-2015)
Old 07-22-2015, 02:09 PM   #8
JS + BRZ
Drives: 2010 MS3
Specifically?
Oh, just the look-wise. haha
Old 07-22-2015, 02:19 PM   #9
SikCee
Pretend Mechanic
Cheers,
shiv
PM'd you
Old 07-22-2015, 02:38 PM   #10
D_Thissen
D_Thissen's Avatar
The problem I with trying to make it like a HUD is you end up with a double image similar to this.
Old 07-22-2015, 02:41 PM   #11
SikCee
Pretend Mechanic
Is it supposed to reflect off the plastic?
I just put an order for this im hoping it will yield a different result.
Old 07-22-2015, 02:55 PM   #12
Shiv@Openflash
Drives: 2013 FRS
Upgraded looks comes last . In terms of functionality, I think the OFT is already at the top of the heap. This isn't to say that the hardware won't evolve over time.
JS + BRZ (07-22-2015)
Old 07-22-2015, 02:59 PM   #13
JS + BRZ
Drives: 2010 MS3
All good! Was just curious.
Old 07-22-2015, 04:00 PM   #14
D_Thissen
D_Thissen's Avatar
I think the double reflection is caused by the windshields construction. The original image from the device would need two images to be off slightly, so that when it reflects in the windshield they line up. I might be wrong but that's how I've always understood it.
hud, idea, oft
DIY Idea OjiGeorge DIY (Do-It-Yourself) Guides 14 08-21-2014 06:36 PM
Is it a bad idea for me to buy this car? irocz0r Scion FR-S / Toyota 86 GT86 General Forum 105 07-07-2014 02:01 PM
An idea... ActionJackson Forced Induction 2 05-28-2014 03:01 AM
Idea for 10 Series Owner, but have no idea how to accomplish. IgnitionGundam Cosmetic Modification (Interior/Exterior/Lighting) 9 10-01-2013 12:29 AM
What do you think about this idea... FRSowner Scion FR-S / Toyota 86 GT86 General Forum 10 07-20-2012 03:26 PM
