| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: White 2013 FRS
DIY Idea
So as many of us have probably noticed, there is some valuable semi-covert storage space behind the passenger-side dash cover. Thought this might be useful for storing away some small items that a would-be thief might not think to check first. We all know storing away lock-nut keys in the glove box almost negates their purpose. Anyone with the know how think this compartment could be easily set up to be opened with a hinge/strong-magnet or otherwise lock to hold it in place? Would keep the stock appearance and provide a slightly better chance of thwarting wood be thieves of recovering valuables such as lock-nut keys or alarm override switches? Also, wouldn't need to pop it off for quick access.
Thoughts? Too obvious? |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
I think there's an airbag back there.
It looks as if there is one, but it's just an open cavity with some support braces. I think the airbag rips through the dash. It's easy to pop off with your fingers if you want to take a look.
LoL sorry, my post wasn't clear at all.
It looks like there should be an airbag behind the passenger dash plate, but I didn't see one. The passenger plate is easy to remove with your hands, it just pops off. |
Drives: FR-S 10 #103 AT
The way it is from the factory should be fine for something like a wheel lock key. How often will you need it?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
The Answer
Drives: Mazda 2
You could remove the pins and glue high strengh magnets ?
Drives: 2013 Subaru BRZ
or just put a little cubby to shove stuff in and leave the cover the way it is since its "easy to pop off with your fingers" like you said.
Drives: Scion FR-S
you could put your weed in there.
#10 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Lol literally the first thing I said when I looked behind the dash plate.
#11 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
I may or may not have used that area for hiding things
. I agree that that is a lot of wasted space. I believe there is no airbag behind it either. It would definitely be a cool place to add something.
#12 |
Drives: 2013 Asphalt 6spd
Just be careful, in some states even if it is empty, just having an accessible hidden compartment in the car is a crime because you "could" use it for drug smuggling.
#13 |
Drives: Scion FR-S
#14 |
Drives: 2014 WRB BRZ Limited
The name of this thread needs to be changed to "DIY pot pocket"
| 225/45/18 Bad Idea? | alex88 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 04-22-2014 11:25 AM |
| Idea for 10 Series Owner, but have no idea how to accomplish. | IgnitionGundam | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-01-2013 12:29 AM |
| Any idea what this is? | idreamofdrifting | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 02-08-2013 10:50 PM |
| Best idea for a bed ever! | dorifuto | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-19-2012 10:34 AM |
| What do you think about this idea... | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-20-2012 03:26 PM |
