Old 11-07-2014, 07:15 AM   #1
impossible
Unhappy weird noise from front left
have just take off the left front wheel to install the front rallyarmor mud flip only but after installation and have a test drive when i turn left ever time could heard some weird noise but i am sure the tyres are not rubbing whats the problem? wheel bearing?
impossible is offline   Reply With Quote
Old 11-07-2014, 07:42 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
A better description of the noise would help..
Does it sound like rubbing? Does it sound like a whirring kind of noise.
Generally if you have a bad wheel bearing you will hear it all the time, it will be louder as you put weight on that wheel.
Shady195 is offline   Reply With Quote
Old 11-07-2014, 09:55 AM   #3
Kaotic Lazagna
Drives: GR Corolla
^ I thought it's louder when there is less load on the wheel with the bad wheel bearing.
Old 11-07-2014, 05:47 PM   #4
impossible
Doesn't sound like rubbing is like a weird noise when I Turning in the corners
Old 11-07-2014, 10:02 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Nope. Opposite but it doesn't really matter if you do the zig-zag thing on some really quiet asphalt. It's easier to hear it come and go that way.
Obligatory saftety tip for everybody - make sure this is done on an otherwise empty strip of road.
Old 11-07-2014, 10:05 PM   #6
impossible
Will it be possible if the lug nuts didn't tight well and loose and cause this sound when turning??
Old 11-07-2014, 10:08 PM   #7
Ultramaroon
not playing cards
You would immediately hear a nasty clunking sound. I'm ashamed to admit I've done it once.
That being said, GO CHECK NOW.
Old 11-07-2014, 10:18 PM   #8
impossible
Nasty clunking noise??
Old 11-07-2014, 10:44 PM   #9
Ultramaroon
not playing cards
Yes. Loud but not just when turning. Why are you even asking about that? Go check.
Old 11-07-2014, 10:44 PM   #10
impossible
Lol my one is not really load just a bit noise when turning
Old 11-07-2014, 10:45 PM   #11
impossible
Yes. LOUD.
Will check when arrive home
Old 11-07-2014, 10:51 PM   #12
Ultramaroon
not playing cards
Ooops... well, that makes sense.
Old 11-07-2014, 11:13 PM   #13
impossible
Old 11-07-2014, 11:21 PM   #14
Ultramaroon
not playing cards
I thought you were trolling asking about loose lugs instead of going outside and checking.
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
Weird Noise FloridaBRZ BRZ First-Gen (2012+) — General Topics 7 04-25-2014 08:35 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-01-2013 11:42 PM
Weird Sound After Coilover Install (when moving steering wheel left and right) taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 07-20-2013 01:18 AM
Weird noise Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 3 08-28-2012 01:46 AM
