Old 07-20-2015, 01:13 AM   #1
swarb
Possible to extend steering wheel closer to the driver?
I am trying to get the steering wheel closer to the driver as I have short arms.
I don't want an after market wheel with no airbag. If I move the seat closer, my legs get cramped. I am already wearing thin soled shoes.
Is it possible to extend the steering wheel closer to the driver?
Does something like a spline spacer with female/male ends to extend the wheel exist? I could use it and push the steering column all the way forward and it would be at the perfect spot.
Any ideas?
Old 07-20-2015, 01:44 AM   #2
BRAWL
Drives: Toyota 86 GTS Velocity Orange
I have thought about moving it, but because I have long legs not short arms
As it's an electric pump it shouldn't be too hard but above my pay scale
BRAWL is offline   Reply With Quote
The Following User Says Thank You to BRAWL For This Useful Post:
swarb (07-21-2015)
Old 07-20-2015, 01:49 AM   #3
ryoma
ryoma's Avatar
I know that this is the most basic question, but is your wheel fully telescoped out?
Old 07-20-2015, 01:54 AM   #4
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
the wheel is adjustable, have you done that?
sittinSideways is offline   Reply With Quote
Old 07-20-2015, 02:02 AM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
This is gonna be good
Instagram: stimson
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Teclis (07-20-2015)
Old 07-21-2015, 01:07 AM   #6
Poodles
Drives: 2015 Series.Blue
Been wondering this myself...
As it is, if I move the seat closer, my legs will cramp because they're not supported by the seat bottom at all. If I sit up more, the back of the seat doesn't fit me properly (shoulders in wrong spot, etc). My arm can't rest on the arm rests and hold the steering wheel unless I lower it all the way down, but then I can't see the dash.
Wish the steering wheel came out just a bit more as it would help a bit. A bit larger steering wheel would help as well (yes yes, I know small steering wheels are sportier)
The Following User Says Thank You to Poodles For This Useful Post:
swarb (07-22-2015)
Old 07-21-2015, 03:20 AM   #7
swarb
Yes, the steering wheel is all the way out. Read the second part of my original post, I mention a spacer and then pushing it forward as I only need it about 20-30mm closer.
I hope to find a solution and it would be better than good.
I don't want to sit at a 85/90 degree angle so my arms are comfortable, but my back/neck is not. I am no where near from sitting laid back stunna' style. The Steering wheel is slightly higher than center so my shoulders are inline with 9/3 o'clock positions as this is the closest distance to the position my arms are at most of the time. I already wear thin soled shoes that does partially help this problem.
Other alternatives which I want to avoid for safety reasons is replacing the steering wheel or replacing the seat. I could probably find some Evo X seats (do they sit lower than stock?) or others, but I would like to keep what I have and not drop a grand.
Old 07-21-2015, 01:40 PM   #8
JDM4E
Drives: Honda Accord Euro
I am with you and I think there were a similar threads like this before. I need 1 inch or so closer. I also remember Chris Harris complaining about it too...
I have no idea why they cannot do the telescopic thing a bit longer. Must cost nothing.
BTW I don't know how the airbag wiring looks like, but with an extender I would consider this as a issue, maybe some airbag extension will be needed too.
JDM4E is offline   Reply With Quote
The Following User Says Thank You to JDM4E For This Useful Post:
swarb (07-22-2015)
Old 07-21-2015, 07:03 PM   #9
ryoma
ryoma's Avatar
I know they make spacers for aftermarket hubs, but I don't think those spacers would work with the stock wheel. I wouldn't ghetto rig anything just to get a little extra length though since it might compromise the safety.
Old 07-21-2015, 07:41 PM   #10
JS + BRZ
Drives: 2010 MS3
Try drinking more milk!?
JS + BRZ is offline   Reply With Quote
Old 07-21-2015, 08:24 PM   #11
8R6
8R6's Avatar
Drives: FRS
is there a way to adjust the pedals to move back a tiny little bit? maybe that'll help (if possible) since the wheel aint getting any closer.
8R6 is offline   Reply With Quote
Old 07-21-2015, 08:36 PM   #12
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
I swear car companies do this because of fat people. Only way I could resolve this issue in my NA Miata was a steering wheel spacer.
Interested to see where this goes. A spacer that plays well with the stock wheel would be a godsend. Maybe Raceseng can fab something up?
sdemo is offline   Reply With Quote
The Following User Says Thank You to sdemo For This Useful Post:
swarb (07-22-2015)
Old 07-21-2015, 09:51 PM   #13
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Even with aftermarket seat, steering wheel will still need to be moved toward you some. Seems manufacturers don't make cars able to put the steering wheel where it needs to be...(maybe because of the airbag though?) I'd love a spacer to get the wheel closer. also rather a smaller diameter and fatter wheel at the same time...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
swarb (07-22-2015)
Old 07-21-2015, 10:09 PM   #14
johan
Drives: '14 981CS, '99 NB1
I feel you OP. I think the same thing all the time. I'm 6'3" and I constantly feel like the steering wheel should be closer. Sometimes when I'm serious about driving, I move the seat forward a click or two so I can have my arms more collapsed to be able to get more rotation out of the steering wheel.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
swarb (07-22-2015)
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Wtb '13 scion frs driver steering wheel airbag air bag mnb0225 Want-To-Buy Requests 0 03-18-2014 06:56 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Extend BRZ Amplifier Harness for Subwoofer console_cowboy Electronics | Audio | NAV | Infotainment 7 04-15-2013 05:58 PM
