Old 07-17-2015, 02:45 PM   #1
snowdog
Drives: 2013 Scion FRS
Turbo planning
Like many others, I have decided that I would like my car to have a little more power, and have decided turbo is the route for me. I have searched all over the forum but did not easily find what I am looking for.
Many threads talk about horsepower goals and then there are discussions on which brand of what will work for their application. What I am looking, for as far as "turbo planning", is at what horsepower thresholds are modifications recommended. For example, what horsepower threshold would it be recommended to upgrade fuel injectors? 250whp? 300whp? what about fuel pump? oil cooler? clutch? etc.
If some of the experts and car gurus could weigh in on what upgrades are needed at what horsepower, it would help me (and I am sure others) decide on horsepower goals. I would be happy to summarize feedback as it comes in.
First post to the site, so go easy on me. If I have missed this thread, please point me to it.
snowdog is offline   Reply With Quote
The Following User Says Thank You to snowdog For This Useful Post:
JS + BRZ (07-17-2015)
Old 07-17-2015, 02:59 PM   #2
MAPerformance
Drives: Asphalt FRS
Welcome to the forum! The stock fuel system can support up to 300whp. So no need for port injectors or fuel pump for that. This is also going to be your expected power level for most (not all) turbo kits, and some supercharger kits out of the box. Fuel also plays a roll as well. Because of the stock high compression, pump gas power is really going to be limited to around 330-350whp reliably. If you want to go higher than that, E85 would be recommended. Stock clutch typically will not support more than 300whp for long periods of time either. Oil cooler in my opinion is a must, even if it's a daily driver. If you plan to track the car, a radiator is not a bad idea either. Also look into catch cans as well. Hope that gives you a good start. PM me with any other questions you may have!
MAPerformance is offline   Reply With Quote
The Following 5 Users Say Thank You to MAPerformance For This Useful Post:
flippy (07-21-2015), kbogarto (07-20-2015), randomthoughts (07-17-2015), ShadowReaper (10-24-2017), ybotspawn (07-17-2015)
Old 07-17-2015, 03:00 PM   #3
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
250whp, 200ft/lbs of torque - you don't need to do much.
270whp, 220+ ft/lbs of torque - your clutch needs to be replaced.
300-315whp, 240+ ft/lbs of torque - you are at the limits of power on pump gas. At and after this point onwards, you need to be looking at e85, and that's where the costs come in. Flex fuel kit, larger injectors, and larger pump.
Your fuel injectors and fuel pump do not need to be replaced if you are running on pump gas, because you'll run into a octane limit before you run into a fuel flow limit.
Oil coolers are dependent upon two factors, your local temperatures and the type of kit you are running.
AVOturboworld is offline   Reply With Quote
The Following 10 Users Say Thank You to AVOturboworld For This Useful Post:
flippy (07-21-2015), Grip Ronin (07-25-2015), IBill4You (07-21-2015), Jrryjms07 (07-20-2015), JS + BRZ (07-17-2015), kbogarto (07-20-2015), randomthoughts (07-17-2015), Raven86Project (04-30-2018), themajesticone (07-17-2015), ybotspawn (07-17-2015)
Old 07-17-2015, 03:18 PM   #4
snowdog
270-300whp for clutch. What threshold for AT?
Old 07-17-2015, 03:26 PM   #5
AVOturboworld
Not as clear an answer on the 6AT. Not for a bad reason, we simply haven't seen many 6AT's grenade.
We've built more than a few 300whp setups for customers with the 6AT, and they've been fine for the last year to 2 years. I'd say you are ok in that range, and budget out for tranny cooler if you are going to planning to track that.
Old 07-17-2015, 04:09 PM   #6
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
as much as i do like the vendors above me in post
give @FullBlown a holler. LJ is truly a helpful individual and made provide excellent customer service.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 07-17-2015, 04:13 PM   #7
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I'm no expert, but my understanding is that the stock AT can handle up to ~275 torques or 350whp. Everyone's experience varies because it depends heavily on how much you abuse your clutch. You could run 800hp through the stock transmission if you babied it everywhere.
As for your initial question: a big consideration is how much you're willing to spend. Here's a rough guideline of what to expect for price to performance when including labor and all the necessary supporting mods:
250-280 whp - $5,000
300-325 whp - $8,000
450+ whp - $10,000
Pay to play lol. Of course, you can save some cash if you buy parts used or get a good deal on labor (or even do it yourself), but in my experience, this is what turbo builds typically end up costing.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 07-17-2015, 04:54 PM   #8
snowdog
So to summarize
* 300-350 whp is limit of pump gas
* No fuel system upgrades while staying on pump gas
* Oil cooler suggested regardless of horsepower goals
* Catch can / air oil separator suggested regardless of horsepower goals
* 270-300 whp limit of stock clutch
* 350 whp limit of AT
Anything else to consider?
Old 07-17-2015, 05:18 PM   #9
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
So to summarize
A list of things like the above would be a great sticky for this forum "FI FAQ." I know we have the buyers guide but that seems to be more based around what can you get for $5,000 as opposed to what will support your power goals.
Obviously you would have to talk about taking the above values with a grain of salt but it would probably save a lot of questions and give people a good idea of where to start, especially people like me who don't have nearly as much experience and would like to have a place to start with the supporting mods they will need based on their power goals. It could even be broken down by ranges of whp goals. I'd do it but I know jack shit compared to most of the people on here.
200-220 whp
-Suggested item 1
-suggested item 2
-so on
220-250 whp
-you get the idea
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 07-17-2015, 05:23 PM   #10
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Subbed!
kayoh is offline   Reply With Quote
Old 07-17-2015, 05:54 PM   #11
AVOturboworld
I think the reason for the confusion is that it has been a learning process on what was and was not needed. Many tuners swore you needed fuel injectors and a pump to even reach 270whp for a while.
It's been a learning process for everybody. Ecutek has been continuously improved since the initial release, and that's changed what was needed as well.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 07-17-2015, 07:38 PM   #12
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
So what truly is the acceptable limit for stock injectors? For example, I am gunning for 300whp on E85 with the JRSC with standard pulley. I've asked three separate Master Ecutek tuners now, and one has said "just injectors", the next said "injectors and pump" and the third said "stick with the stock injectors and get a fuel pump".
So which is it? I have full bolt ons already (if that makes a difference). But if I can safely get away with NOT buying injectors then I would of course love to go that route.
Thoughts?
xsnapshot is offline   Reply With Quote
Old 07-17-2015, 08:18 PM   #13
D_Thissen
D_Thissen's Avatar
At what point should someone consider upgrading internals? Would you be able to run a stock bottom end at 225-250 to the wheels? (I am guessing you would only be running around 5-7psi to achieve that.) Then above say 300whp start thinking about upgrading rods/pistons?
Old 07-18-2015, 07:29 AM   #14
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Not all turbos are equal. Some turbos are 250 at 7psi while others are 300 at 7psi. You gotta look at the turbo itself. Some turbos are just oil and others are water/oil.
Study your ass off and look at all your options for all your kits.
GsxrMe is offline   Reply With Quote
horsepower, planning, threshold, turbo, upgrade, wheressquadroguethesedays
Planning on buying a FRS, Need help. dragonboy221 Scion FR-S / Toyota 86 GT86 General Forum 66 02-12-2015 04:32 PM
Need help: Planning to buy... duasto Scion FR-S / Toyota 86 GT86 General Forum 2 09-01-2014 06:10 PM
Subaru planning BRZ special edition for United States, still no turbo - report vh_supra26 BRZ First-Gen (2012+) — General Topics 21 03-17-2014 01:47 PM
FRS roadtrip planning. Ludacrits Scion FR-S / Toyota 86 GT86 General Forum 3 10-16-2013 01:17 AM
Planning on buying a new car rcm47 Other Vehicles & General Automotive Discussions 2 09-07-2013 02:35 PM
