Drives: Scion FR-S
Torque specs (brakes)
Does anyone know what are the factory torque specs for front/rear brake brackets and for the calipers?
Thanks! |
Drives: Scion FR-S
Well, I've used the torque wrench to loose bolts, here is what I measured (front):
guide bolt: 20 lbf caliper-to-bracket bolt: 105 lbf. Will do rear later today. I think 10% should be added. |
whoa, that sounds high
try 85! (just a guess) If someone knows the factory spec or can tell us what the right number is that would be great torque to break a fastener and the torque to load on are NOT the same, beware that type of thought, can hurt you more than it can do good |
Drives: Scion FR-S
I don't know how trustworthy is this: http://www.torkspec.com/torkspecmm.aspx?KI=494
But it calls for 114 ft-lbs (17 inch type). Very similar brakes. |
Drives: CBS BRZ Limited
Front caliper carrier is 59 lb-ft
Rear caliper bracket is 49 lb-ft Those numbers should be right if I read the schematics from the service manual correctly. You can download the FR-S shop manual here: http://www.ft86club.com/forums/showthread.php?t=12135 |
| The FRS torque curve | smbrm | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-30-2016 04:10 PM |
| Wheel Re-Torque to 89 ft-lb | Brzce | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 08-22-2012 10:55 PM |
| It has more power, but less torque. | white_knight | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-09-2012 01:46 AM |
| Torque Specs for Factory Brace | schtebie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-06-2012 12:46 PM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
