Old 07-08-2015, 02:17 AM   #1
wootwoot
Drives: FRS
Double sided tape
Does anyone have any idea if Toyota sells the double sided tape they use on the TRD body kit and spoiler? The stuff I pulled off the spoiler, for example, was really thick and it's hard to source. I also don't know the exact thickness I need. If Toyota stocks a particular size that would help. Ideas?
wootwoot is offline   Reply With Quote
Old 07-08-2015, 02:46 AM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
3M tape, unless toyota's is already rebranded 3M.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
DieselDog (07-11-2015), Packofcrows (07-08-2015)
Old 07-08-2015, 10:55 AM   #3
wootwoot
Drives: FRS
I know, but it isn't standard double sided tape. It's more like foam tape. And it's fairly thick.
Old 07-08-2015, 11:26 AM   #4
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
I would still recommend 3M Automotive Acrylic Plus tape. I never see it in stores though; I usually just see the "Super Strength Molding" tape which is not as good as the Acrylic Plus.
malave7567 is offline   Reply With Quote
Old 07-08-2015, 02:33 PM   #5
wootwoot
Drives: FRS
That's exactly what I ordered but it's too thin. The oem white tape is over 1/4" I think.
Old 07-08-2015, 02:36 PM   #6
swarb
Maybe try using two layers?
Old 07-11-2015, 01:38 AM   #7
wootwoot
Drives: FRS
Anyone else? Two layers isn't thick enough.....
Old 07-13-2015, 04:12 PM   #8
wootwoot
Drives: FRS
One last bump as a last ditch effort. I've searched for hours on the net, made all sorts of calls, and can't find anything thick enough. I need a minimum of 1/4" thick. Anyone?
Old 07-13-2015, 04:32 PM   #9
DAEMANO
Time Traveller
Start at findtape.com
Here:
http://www.findtape.com/category/foa...b&holiday=none
and/or
Check their foam tape comparison matrix
http://www.findtape.com/shop/compari...LH0Ej3l&cid=23
And if you can't find it from one of those links, call their number 1-800-806-7580
Lastly... if you end up using 3M automotive tape, make sure to use 3M 4298 adhesion promoter. It will make certain that your parts are going nowhere. It's also very cheap on the same website in swabs or a larger bottle container.
http://www.findtape.com/product605/3...sion+Promoter+[Bottle]
Old 07-13-2015, 04:38 PM   #10
adamg
Drives: brz
use 3 layers ¯\_(ツ)_/¯
adamg is offline   Reply With Quote
Old 07-13-2015, 09:49 PM   #11
stevesnj
stevesnj's Avatar
Pics here may help
http://www.ft86club.com/forums/showthread.php?t=11993
My 2016 Build thread
Old 07-14-2015, 08:34 PM   #12
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Google 3M VHB tape. You can get it in as thick as .090" Which is really fucking thick for tape. .250" thick tape probably wouldnt do well holding anything together. Thats like window gasket sealer thick.
xkalelx is offline   Reply With Quote
Old 07-14-2015, 09:58 PM   #13
wootwoot
Drives: FRS
.250 is how thick the stock stuff is.....
Two-Sided tape for Aero parts Freude am Fahren Cosmetic Modification (Interior/Exterior/Lighting) 9 12-15-2017 05:39 AM
Double sided tape for spoilers? MileHighBRZ Scion FR-S / Toyota 86 GT86 General Forum 21 05-20-2015 12:47 AM
which 3m tape is this? mokinbird87 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-29-2013 09:12 PM
3M double sided tape for FR-S emblem denverizzles Cosmetic Modification (Interior/Exterior/Lighting) 0 07-19-2012 11:03 PM
