Old 07-04-2015, 04:32 AM   #1
eric2523
Drives: Subaru BRZ '13 Limited
Springs dangerous for car?
Bought the car used for around 30,000 miles with stock everything and with about 33k miles on it now im thinking about buying/installing springs however worried that it will be damaging the car's struts.
eric2523 is offline   Reply With Quote
Old 07-04-2015, 11:23 AM   #2
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
As long as you stick with springs made to work well with the stock struts you will be fine on this car. These are ones with drops less than an inch, and rates that are not too agressive. RCE yellows, Swift Sports, Eibach Pro-kit, RS*R down, TRD springs, and others.
TheVoiceOfReason is offline   Reply With Quote
The Following User Says Thank You to TheVoiceOfReason For This Useful Post:
Shankenstein (07-04-2015)
Old 07-04-2015, 11:32 AM   #3
D_Thissen
D_Thissen's Avatar
IIRC RCE yellows were designed to work with the OEM struts. I have had them on my car for about 5000km and they haven't made so much as a squeak.
The Following User Says Thank You to D_Thissen For This Useful Post:
tinma (07-04-2015)
Old 07-04-2015, 12:12 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Maybe RCE yellows are made for stock .. but most often i hear them mentioned together with Koni shocks.
Old 07-04-2015, 12:22 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Lowering springs dont damage struts. If anything an improperly designed spring (outside the dampers critical damping zone) undersprung or oversprung will wear the damper down faster than the stock springs. No one has reported damage from just springs.
Old 07-04-2015, 12:39 PM   #6
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Some people have reported damage on Eibach Sportline and other springs that drop >1.0", but it's fairly rare... and may be attributed to people who install the strut's top nut with an impact wrench (which can wear the seals).
If you do springs, keep the drop modest (less than or equal to 1"). Check the spring rate, to make sure is appropriate for your drop level. As others have mentioned, RaceComp Engineering's Yellow springs have alot of happy customers for good reason. See the above criteria.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
cdrazic93 (07-04-2015)
Old 07-04-2015, 07:13 PM   #7
wparsons
wparsons's Avatar
Keep in mind that most shock manufacturers suggest replacement around 50k miles, so even if the springs alone aren't damaging to the shocks, they might not last a ton longer.
I've personally got swift sport (frs rate) springs on stock shocks with 103k km's on them, with about 40k km's of those with the swift springs and they're still working great.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
D_Thissen (07-04-2015)
Subaru sued over claims of dangerous auto defect carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 1 07-19-2014 09:34 AM
Stock pads dangerous in cold/wet @ highway speeds? SloS14 Issues | Warranty | Recalls / TSB 14 03-09-2014 03:26 AM
AVIC dangerous driving warning Ben_G CANADA 14 11-25-2013 04:33 AM
some dangerous racing right here - anyone got more info? 7thgear Tracking / Autocross / HPDE / Drifting 19 09-12-2013 04:49 PM
Bad/Dangerous Driver Mr.Jay Off-Topic Lounge [WARNING: NO POLITICS] 31 03-20-2013 09:25 PM
