Old 07-02-2015, 11:50 AM   #1
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
No lugnut inserts acceptable for street use?
So my question is pretty much what the title states: I have Motegi Traklites and they do not use a steel insert for the lugnut to seat against. I assume the rationale was to shave as much weight as possible, but I'm wondering if it will pose any durability/longevity issues on the street? I usually check torque once a month or so, and so far none of the nuts have been loose. I suppose a machine shop could drill out/press in inserts to make them a little more durable....just wondering if I'm worrying about a non-issue.
venturaII is offline   Reply With Quote
Old 07-02-2015, 12:30 PM   #2
Poodles
Drives: 2015 Series.Blue
It's fine. It's actually relatively rare for a wheel to have steel inserts for the lug nut seats.
Old 07-02-2015, 12:38 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Stock wheels have inserts because it makes the wheel more durable in the long run, plus removes the wheels as a point of failure when all said and done.
This is a non-issue unless you are driving your car as if it was still on stock wheels.
-alex
Old 07-02-2015, 01:03 PM   #4
venturaII
venturaII's Avatar
Really? I can't recall a set of aluminum wheels (stock or aftermarket) NOT having them...
Originally Posted by mav1178 View Post
This is a non-issue unless you are driving your car as if it was still on stock wheels..
Not sure what you mean by this...?
Old 07-02-2015, 02:09 PM   #5
mav1178
mav1178's Avatar
Just wheels I've personally owned on this car:
Weds Sport TC105n
Work VS-XX
Volk RE30
Volk ZE40
Advan RG-D
Advan F15
Enkei RPF1
None of those had steel lug seat inserts.
The reason why OEM wheels weigh a ton and also have these is for long term strength and durability. It's cheaper for them to overbuild the wheels so you can drive it on virtually any type of surface and not have any issues.
Newer factory wheels with a better supplier have designs without a lug seat insert. It all depends on whether it can meet stress/impact tests as determined by the manufacturer.
Once you move to more high-end performance cars, you'll start finding OEM wheels without lug seats.
-alex
Old 07-02-2015, 03:46 PM   #6
Poodles
-alex
Most stock wheels don't even have them either. Never had them on any of the cars I've owned or worked on...
Odd note is that I noticed that the brands of wheels that my local Subaru dealer has on display DO have inserts. I thought it was odd at the time since I've never seen inserts used before Maybe it has something to do with rally or something...
And like I said, never seen a set of wheels with them until recently. I don't think my STI wheels have them either...
Old 07-02-2015, 03:53 PM   #7
venturaII
venturaII's Avatar
Hmm...I still have a set of OEM Benz wheels from my last car...I'll have to check again; I'd swear they had them, as well as my Jeep. Regardless, as long as I keep an eye on torque, it sounds like I'm fine. Thanks!
Old 07-02-2015, 04:26 PM   #8
mav1178
mav1178's Avatar
A lot has to do with the OEM supplier and what they paid for from a manufacturing perspective. Mine is more of a blanket statement... but many modern cars don't have inserts in their alloy wheels.
-alex
***EVASIVEMOTORSPORTS LUGNUT SALE*** RAYS,KICS,MUTEKI,BLOX,EVS,WEDS,BUDDYCLUB, Evasive Motorsports Wheels and Tires 10 09-04-2015 07:21 PM
FS: BLUE Light weight forge aluminum Lugnut in Socal mtsui Wheels and Tires 2 05-28-2014 03:47 AM
Swap My FR-S Fender Inserts for Your BRZ Inserts (White, Central Jersey) Figo NY / NJ / CT / PA 1 03-06-2014 11:26 AM
Don't expect acceptable service from Wilwood swift996 User/Vendor/Sponsor Reviews, Feedback, Comments 1 10-30-2013 04:58 PM
Acceptable helmet suggestions. jadewbj Tracking / Autocross / HPDE / Drifting 40 10-03-2012 03:59 PM
