Old 06-30-2015, 10:20 PM   #1
bozack
Drives: 2013 Firestorm Red FR-S
Which Intake for the FR-S?
I'm between both Perrin and Mishimoto, box or mounted in the front bumper?
bozack is offline   Reply With Quote
Old 06-30-2015, 10:24 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
None of the above.
http://www.ft86club.com/forums/showt...ghlight=intake
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
GrimmSpeed (07-01-2015), Hyper4mance2k (07-01-2015), WhiteFRS69 (06-30-2015)
Old 06-30-2015, 10:30 PM   #3
bozack
So Grimspeed is your suggestion?
Old 06-30-2015, 11:11 PM   #4
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
yes! my suggestion too! grimmspeed has hands down some of the best made quailty parts IMO
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
Old 06-30-2015, 11:15 PM   #5
Captain Snooze
Drives: Red Herring
Plus they do extensive testing (which they share) to support their product releases.
Old 07-01-2015, 12:20 AM   #6
bozack
The Mishimoto intake is just about the same thing. Is it not? Not trying to sound like a asshole.
Old 07-01-2015, 12:30 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
I'd say none purely from reasons that i value most upgrades by their price/performancy. Aftermarket drop-in filter will net you 2/3rds of gains of full intake for 1/5th of price. And less non-stock parts - often better resale value or less stock things to bolt back before sale
For this platform main way to get extra power in NA is header+tune. Only if that's already upgraded, and one must absolutely squeeze anything left to gain (with diminishing returns, as many parts gains don't stack), then also catback exhaust & intake.
The Following User Says Thank You to churchx For This Useful Post:
kch (07-01-2015)
Old 07-01-2015, 12:39 AM   #8
bozack
I have the header/exhaust/stage 2 tune/light weight crank pulley/oil cooler kit/mishimoto radiator....had AEM intake, but it did not fit after the oil cooler kit install.
Old 07-01-2015, 01:53 AM   #9
themajesticone
themajesticone's Avatar
Drives: '13 UM86
< 243 whp NA
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 07-01-2015, 03:38 AM   #10
Captain Snooze
Drives: Red Herring
It is often the case that better flow comes at the expense of worse filtration. As it is impossible to find test data on filtration for each filter one doesn't know how much, if any, extra solids are being ingested by the engine. I do not know if it is significant; just that there is no free lunch.
Old 07-01-2015, 04:04 AM   #11
Poodles
Drives: 2015 Series.Blue
Oil analysis will have excess silica from a crap filter... There has been testing years ago as well (mainly for Supras but the different brands haven't really changed their tech at all)
The Following User Says Thank You to Poodles For This Useful Post:
Captain Snooze (07-01-2015)
Old 07-01-2015, 10:10 AM   #12
OkieSnuffBox
Drives: '23 BRZ Limited
Do you want to support a company that spends money/time developing parts that deliver a proven performance increase?
Or
A company that is widely seen as copying the designs of the former?
Old 07-01-2015, 11:21 AM   #13
Mishimoto
Drives: 2013 Subaru BRZ
Thanks for considering one of our intake systems for your FR-S! As noted, we have two different setups depending upon what you are looking for in terms of performance and filter servicing.
Cold-air System (Behind the Bumper)
http://www.mishimoto.com/subaru-brz-...intake-13.html Basic Specs
  • Direct fit for the 2013+ Subaru BRZ and Scion FR-S
  • Provides 10 whp / 8 wtq gains while maintaining A/F ratios with no additional tuning
  • Mandrel-bent aluminum intake piping includes CNC-machined MAF housing and air straightener
  • Fully serviceable oiled air filter provides 16% increase in filter surface area compared to the stock filter
  • Available with a polished or wrinkle black finish
  • Powder-coated air diverter plate provides ample airflow to both the radiator and intake filter
  • Improves engine tone
  • True cold-air design places the filter outside the hot engine bay
  • Smooth piping eliminates restrictions and improves airflow
  • Mishimoto Lifetime Warranty
Product Design and Testing: http://engineering.mishimoto.com/?cat=112
Engine Bay Performance Intake
http://www.mishimoto.com/subaru-brz-...take-2013.html
Basic Specs
  • Provides 7 whp / 5 wtq gains while maintaining A/F ratios with no additional tuning
  • No bumper removal required and installs in under 30 minutes
  • Designed to fit with the Mishimoto BRZ / FR-S Oil Cooler Kit and Mishimoto Oil Fill Cap
  • Black powder-coated airbox keeps unwanted hot air from entering the air filter
  • Wrinkle black aluminum intake pipe includes CNC-machined MAF housing and air straightener
  • Smooth design eliminates restrictions and improves airflow
  • Available with a black, blue or red silicone induction hose
Product Design and Testing: http://engineering.mishimoto.com/?cat=260
Our performance intake is currently available via a discounted pre-sale at the rate of $275. Let me know if I can answer any questions about either kit.
Thanks
-John
Or
We design all of our intake systems in-house and do not "copy" any products during the process. The airbox setup was designed to take advantage of the factory intake air duct, which means (like most intake systems) the airbox placement is similar. The products in question may be similar, but are in no way identical. Our airbox is specifically designed to fit with our air filter and to function with our oil cooler sandwich plate. These were two important factors that impacted our final design.
Thanks
-John
Mishimoto is offline   Reply With Quote
The Following User Says Thank You to Mishimoto For This Useful Post:
bozack (07-01-2015)
Old 07-01-2015, 12:13 PM   #14
bozack
Originally Posted by themajesticone View Post
< 243 whp NA
How in the hell
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 01:44 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
