Drives: 2013 Raven FRS
Open flash header and catless front pipe and unresonated exhaust review
I just installed my OFH combo with P&L over pipe, P&L catless front pipe and unresonated perrin 2.5" exhaust.
My original intent was to reduce the torque dip with the stage 2 open flash tablet. The gains and improvement is incredible. The only drawback for this set up is the extreme drone and rasp. I don't mind the loud exhaust drone but the metallic rasp is gets annoying at high rpm over 3500. I realized that for a daily city driver it may not be ideal both for the rasp and raw exhaust smell. I am now contemplating on getting a high flow catted front pipe. It gets embarrassing driving a 200hp car that sounds like a loud Honda fart can. I don't think there is a huge loss of torque and hp going to a catted front pipe. I tried looking up and did not see many discussion. Thoughts?
| The Following User Says Thank You to FrostedFlakes For This Useful Post: | bedabi (06-30-2015) |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
get a resonated mid pipe for the perrin, (or have one welded in) and get a resonated or catted front pipe. (or again have one welded in)
I ran a fully catless set up with a resonated front pipe (Helmholtz) and resonated perrin and i had 0 rasp.
This is your life and it's ending one minute at a time.
| The Following User Says Thank You to RobertPaulson For This Useful Post: | FrostedFlakes (07-01-2015) |
Drives: 2015 BRZ Series.Blue
How many times can this question possibly be asked?
If you are going to run a catless exhaust system, you MUST use at least two resonators.....HKS dual resonated front pipe and cat-back resonated will eliminate drone. |
| The Following User Says Thank You to s30series For This Useful Post: | Chad11491 (06-30-2015) |
Drives: 2013 FR-S, 2016 Miata Club
Go back to stock catback. Try it. Should be a simple swap out.
| The Following 3 Users Say Thank You to JimmyMac For This Useful Post: |
Thanks for the feedback guys. Didn't mean to beat this topic to death.
As mentioned I don't mind the drone. I just didn't anticipate the rasp to be that bad. I will definitely look into a high flow catted front pipe in the near future. |
Alexandrino_Auto
Drives: series.Blue
As mentioned a resonator wil help with the rasp. A 200 count HFC won't help much, but it will a bit.
I cant get over the fact that people are shocked that these cars get raspy when opened up. The more retarded the timing, the more retarded the exhaust cam gets, and the higher compression the engine, the louder, higher pitched, and raspier the exhaust note gets. That's just how the car was designed. It's like complaining about a diesel engine that knocks... Our cars sound like a Honda because the FA20 basically a flat K20... with poorly designed heads, so it makes less power.
The Shadetree Project: I turn wrenches
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | FrostedFlakes (06-30-2015) |
Drives: 2013 FRS
When going cat-less, resonators are your friend!
| The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post: |
@Shiv@Openflash
What about tossing the OEM front pipe back in? Would that make a difference? Is the stock front pipe, in your experience, too restrictive for car with just bolt ons?
#9 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Nearly nothing past the header is restrictive if you're Naturally Aspirated. Honestly, maybe 2-4hp gain if you change from stock. In addition, whenever you pair a header with ANY catback it will sound different and way louder than the catback with stock header (where most designers test) My .02
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| The Following 4 Users Say Thank You to Aztec For This Useful Post: |
#10 | |
Drives: 2017 Golf R
#11 | |
From everyone's comments I am starting to reconsider looking towards getting a proper resonator instead of the catted front pipe. Just wondering if one Perrin resonated mid pipe would be enough or would the HKS dual resonated front pipe be the better option? From what I think... The Perrin should have a longer resonator on the mid pipe as opposed to HKS two smaller resonators? |
#12 | |
Drives: 2017 Golf R
| The Following User Says Thank You to RobertPaulson For This Useful Post: | FrostedFlakes (07-06-2015) |
#13 |
Alexandrino_Auto
Drives: series.Blue
It's going to cut out a lot of the rasp, but not all of it. I added a vibrant resonator to my HFC Berk Front-pipe, I have a HUGE Magnaflow resonator, and there is still some rasp. I have zero drone, and zero rasp at light throttle and just regular driving, but once you get into it, it's raspy, but I like it. It sounds like any other modern NA engine. The Jaguar F-Type and 911 GT3 have some rasp at the top of their rev range.
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | FrostedFlakes (07-06-2015) |
#14 |
Turning is for Nerds
Drives: 35 characters is not enough
Not an OFH, but the stock resonator on the mid-pipe does a pretty good job at cutting rasp. No cats or other resonators in my system.
[ame="https://www.youtube.com/watch?v=eNiwGXRrQC8"]Scion FR-S Tomei UEL - YouTube[/ame] |
| P&L Catless/Unresonated Front Pipe | WRKHARD | Engine, Exhaust, Bolt-Ons | 2 | 04-21-2015 12:53 PM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| Open Flash Header Catless Clip | Vmax911 | Engine, Exhaust, Transmission | 25 | 03-08-2014 06:51 AM |
| EVS Tuning SSP Exhaust + Catless Front pipe - Review | 8686 | Engine, Exhaust, Transmission | 9 | 01-21-2014 06:50 PM |
| Catless header... o2 bungs before/after front pipe cat? | Thorpedo | Engine, Exhaust, Transmission | 5 | 11-18-2013 11:59 AM |
