Old 06-29-2015, 06:57 PM   #1
tslyw
water in rear tai lights
has anyone else noticed water in their rear tail lights? is this a common problem? Is it just a broken seal? and lastly, is it covered under normal warranty?
tslyw is offline   Reply With Quote
Old 06-29-2015, 06:58 PM   #2
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
It's condensation. It's normal, you can get new thicker gasket to fix the problem. And yes it is covered under warranty.
Fix #1: http://www.ft86club.com/forums/showthread.php?t=26217
Fix #2: http://gasketninja.com/
Rabbit of Caerbonnog is offline   Reply With Quote
The Following 2 Users Say Thank You to Rabbit of Caerbonnog For This Useful Post:
Tcoat (07-03-2015), tslyw (06-29-2015)
Old 06-29-2015, 07:00 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
yes its a known problem on the 2013 models, i believed they fixed the problem in 2014 models and newer
bring it back to the dealership, they should replace it for you
if and when they do replace them, if you are nervous going forward
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
tslyw (06-29-2015)
Old 06-29-2015, 07:00 PM   #4
WhiteFRS69
WhiteFRS69's Avatar
beat me to it
The Following 2 Users Say Thank You to WhiteFRS69 For This Useful Post:
Rabbit of Caerbonnog (06-29-2015), tslyw (06-29-2015)
Old 06-29-2015, 07:11 PM   #5
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
tell them that forum members sent you and they will give you free animals to take home with you. i got crickets but maybe you'll get something better!
cdq85 is offline   Reply With Quote
The Following 4 Users Say Thank You to cdq85 For This Useful Post:
finch1750 (12-26-2017), Rabbit of Caerbonnog (06-29-2015), Tcoat (07-03-2015), WhiteFRS69 (06-29-2015)
Old 12-25-2017, 11:46 PM   #6
kgc
Drives: 2013 Subaru BRZ Limited AT
Mine is out of warranty. Was there a TSB for it?
kgc is offline   Reply With Quote
Old 12-25-2017, 11:57 PM   #7
Decep
Drives: 2013 FR-S Series 10
yes. there's a zillion threads on this.
the fix was pretty simple, they added an adhesive strip to the foam gasket after 2013 afaik.
Old 12-26-2017, 12:20 AM   #8
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Both FRS and BRZ TSBs listed here include the condensation issue. Look down the headings and click
http://www.ft86club.com/forums/showthread.php?t=21868
nzer is offline   Reply With Quote
Old 12-26-2017, 12:20 AM   #9
If out of warrenty just do what the second post in this thread says.
Old 12-26-2017, 02:59 AM   #10
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
It surely will buff out
Or wait till January 7th when the sun comes back for sure
ToySub1946 is offline   Reply With Quote
Old 12-26-2017, 12:28 PM   #11
dnieves
Drives: FR-S 10 Series
The gasket ninja worked liked a charm (identical to OEM but much thicker). I substituted the recommended 3M adhesive with an adhesive silicon from Home Depot (made by GE) because of the horror stories of the 3M product arriving in the tube dried out or becoming brittle over time.
It also give you an opportunity to clean out the crud that gathers behind the tail lights. When you do this make sure you have some touch up paint handy (the last thing you want is rust from chipped paint around the mounting holes).
dnieves is offline   Reply With Quote
Old 12-26-2017, 12:47 PM   #12
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Extremely normal. My tails went for 50k without any condensation. Fortunately I believe the fix is quite cheap and if not replacing OEM Tails is extremely easy if you can find a cheap pair for sale on facebook. I see them being sold for under $100 a set quite often.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 05-18-2019, 02:14 PM   #13
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
So what is the ACTUAL way that water enters? I'm having a hard time understanding why a gasket is needed at all. I've never encountered this on other cars
I have one tail light on my 2014 that is filling with water like an aquarium. I took it off, tilted it in every imaginable orientation, and it seems to be sealed, with the exception of the non-LED turn signal bulb opening. Is that all the gasket is actually protecting?
Also, do the tail light assemblies come apart?
pushrod is offline   Reply With Quote
Old 05-08-2022, 08:28 PM   #14
InspGadgt
InspGadgt's Avatar
Drives: 2015 Scion FR-S (Asphalt)
I find it odd that the issue is with a foam gasket when the turn signal has no o-ring to seal it. The brake light has a gasket but the turn signal does not.
InspGadgt is offline   Reply With Quote
Potential design flaw with factory rear suspension? (WATER in boot area) WTF Suspension | Chassis | Brakes -- Sponsored by 949 Racing 243 07-26-2018 04:06 PM
Possible to keep rear lights on with DRL? cawith Cosmetic Modification (Interior/Exterior/Lighting) 3 03-08-2015 06:05 PM
Trunk - water leak (not rear lights) PeterK Issues | Warranty | Recalls / TSB 18 06-15-2014 10:06 AM
Does anyone have the rubber plugs on the struts from rear suspension to avoid water ? dssence Scion FR-S / Toyota 86 GT86 General Forum 0 02-04-2014 04:31 PM
Water in reverse lights roddy Scion FR-S / Toyota 86 GT86 General Forum 30 05-09-2013 10:18 AM
