Old 03-04-2015, 08:16 AM   #1
cawith
Drives: Toyota GT86 6M/T
Question Possible to keep rear lights on with DRL?
Hi guys,
I have a EU spec GT86, which came with DRL and xenon headlights.
As it is right now, when the light switch is on auto, in daylight the xenon is off and only the DRL LEDs are on, but the rear LEDs also turn off.
Is it possible to get the rear LEDs to stay on in daylight also? I'm asking because because it's going to be required by law starting January 1st 2016, and my guess is that Toyota either say it's not possible, so I'll just have to drive with the lights fully on all the time, or it's very difficult to change and request a lot of money for it. I haven't talked to them about yet though.
Would a simple re-wiring at the fusebox do the trick?
Thanks!
Casper
cawith is offline   Reply With Quote
Old 03-04-2015, 10:15 AM   #2
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
The tailights and DRL are both controlled by the main body ecu. It has a ground output for each relay. You would have to wire it so the drl output is turning on both relays.
Scenic Driver is offline   Reply With Quote
Old 03-04-2015, 11:13 AM   #3
cawith
Okay, so does that mean it's not as easy as just rewiring a cable or two in the fuse box below the steering wheel?
Old 03-08-2015, 05:05 PM   #4
cawith
Can anybody show or explain to me, how I would do the wiring?
Valenti Rear Lights Fog mervingee Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2015 08:58 PM
New HSV GTS tail lights look 86 from rear 000 Racing AUSTRALIA 6 06-15-2013 07:02 PM
Rear Fog lights question! 86driver Scion FR-S / Toyota 86 GT86 General Forum 11 05-13-2013 10:35 PM
Rear lights can't come on zex Issues | Warranty | Recalls / TSB 2 01-30-2013 10:42 PM
Rear lights difference… gtaqv Scion FR-S / Toyota 86 GT86 General Forum 15 01-26-2012 11:59 AM
