Old 06-29-2015, 05:37 PM   #1
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
What coilovers can be close to stock height?
What coil overs can be close to stock height? Really can't drop car much our roads down here suxxxx so bad and floods a lot.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 06-29-2015, 05:49 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Any.
Old 06-29-2015, 05:53 PM   #3
zoth
zoth's Avatar
Originally Posted by mav1178 View Post
Any.
Thanks, but I think a lot of them can't reach stock height. Like the Fortune 550 that I'm looking at would be of a 1/4" plus settling in would probably be 1/2" to 3/4". So far this are best best. Skunk coils out of the is 1" drop already.
Sent from my SM-N900T using Tapatalk
Old 06-29-2015, 06:19 PM   #4
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
I have done a little bit of search myself for coilovers that can be put back to stock ride height as i would need to for the winter. i realized as you that the fortune auto 500 even at full raised height are still lower then stock. all i found as of now is the RS-R i-sports or moto-specs coilovers. i would assume Ohlins would as they are not meant for slamming the car. maybe KW's as well.
BoxRZ_86 is offline   Reply With Quote
Old 06-29-2015, 06:39 PM   #5
KoolBRZ
KoolBRZ's Avatar
The HKS hipermax GT IV's can actually be .5 " higher than stock height. I have them on right now, lowered for summer now, but they were raised for the winter.
Old 06-29-2015, 06:42 PM   #6
wparsons
wparsons's Avatar
Why are you looking at coilovers if you don't want it lower?
flickr
Old 06-29-2015, 06:44 PM   #7
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I have a set that has a range of +2" to - 2" in the front and +1" to -1" of adjustment in the rear depending on the spring rate.
Old 06-29-2015, 07:10 PM   #8
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I could verify that the Ohlins can go to stock height (and higher!)
Old 06-29-2015, 07:10 PM   #9
mush
mush's Avatar
feel like wasting money huh? i think bilstein b14 could go higher than stock, they dont advertise it tho
Old 06-29-2015, 07:17 PM   #10
stugray
Drives: 2013 GBS BRZ Limited
So the OP wants to remove the stock coilovers and replace them with after-market coilovers with the same height....
Might as well get the same spring rate and color too.
Cuz Racecar!
The Following 3 Users Say Thank You to stugray For This Useful Post:
Hyper4mance2k (06-30-2015), superleggera (06-29-2015), wparsons (06-29-2015)
Old 06-30-2015, 12:17 AM   #11
zoth
zoth's Avatar
Better ride..
Old 06-30-2015, 01:23 AM   #12
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Better ride..
As in a softer, plushier ride?
Not gonna happen... maybe with air supension...
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
wparsons (06-30-2015)
Old 06-30-2015, 02:09 AM   #13
KoolBRZ
KoolBRZ's Avatar
Better ride..
The GT IV's actually have a better ride. They are designed for daily driving street use. They have threaded mounts, so you can raise and lower the ride height without affecting the spring preload. They aren't very expensive, and yet they handle well. I would also suggest softer sway bars and Spoon rigid collars. That will firm up the body mounts, yet leave the suspension pliable enough to absorb bumps without passing it through the body to the driver. I also recommend 16" rims with 60 series tires for daily driving, and then Michelin PSS on stock 17's for track/performance use
The Following User Says Thank You to KoolBRZ For This Useful Post:
zoth (06-30-2015)
Old 06-30-2015, 07:47 AM   #14
wparsons
wparsons's Avatar
Better ride..
You're going to be spending a lot to get that... most cheaper coilovers are aimed at making the car lower, not riding or handling better.
To get a softer ride you're going to need softer spring rates than stock, and custom valved shocks. You may find with soft enough rates to get the ride you want, you run out of bump travel on anything off the shelf as well. Even totally stock there is only 2.5" of bump travel, you'll want like 4" if you're going to soften the springs.
Even the Bilstein coilovers with progressive springs are stiffer than stock.
If you want to do it on less money, get the softest combination of stock springs (FRS front, BRZ rear) and custom valved koni or bilstein shocks. I doubt you'll see enough improvement to justify the cost of the shocks though.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
zoth (06-30-2015)
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
Stock Ride Height? JimmyMac Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-10-2015 11:46 AM
Ride height issues with coilovers wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-27-2014 11:09 AM
Post Your Stock Height 86! VakaGT FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 03-19-2014 07:09 AM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 08:35 AM
