Old 06-29-2015, 01:45 PM   #1
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Bogged engine down while turning, electric steering warning light comes on
Chalk this one up to a Monday drive and not doing the clutch/gas thing properly... bogged the engine down a bit while making a left turn at an intersection from a stop. RPM probably dipped a bit over 500 rpm and heard a beep, and the light for the electric power steering came on. Stopped, turn off and on the car, no more light. Did notice that when the engine shut off it felt like it turned over a few more times which has never happened previously. Oh, and the clock reset itself to 1:00.
Decided to do a quick test at a stop light (probably not a good idea), stalled the car intentionally, then everything went dark. RPM gauge stuck at 500 RPM. Crap, light turns green, hit the start button, nothing, had to wait about five seconds then things started up. Guessing the security system needed to power up or reset to recognize the key fob. Again, clock at 1:00.
Got back to work after lunch, this time in the parking lot, stalled the car, radio and everything still running, clock didn't reset itself, etc.
Any ideas on what could be happening? Low battery or alternator on the way out? Did search and couldn't find anything similar.
Mike
tanner is offline   Reply With Quote
Old 06-29-2015, 02:12 PM   #2
humfrz
Well, now, @tanner ...... I suggest you just quit intentionally stalling your car .....
Here is a handy guide to checking your battery and alternator.
http://www.aa1car.com/library/battery_runs_down.htm
humfrz
Old 06-29-2015, 02:16 PM   #3
tanner
Ha for sure
Yeah as soon as I get home tonight, will take a look at the battery voltage with Torque or with an actual meter....
Mike
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 08:53 AM
Heavy steering when turning left... Venator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-10-2015 03:07 PM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 08:38 PM
Toning down the electric steering pump possible? kertong BRZ First-Gen (2012+) — General Topics 18 03-03-2013 12:51 PM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
