Old 02-05-2013, 11:13 PM   #1
kertong
Drives: 2013 BRZ Limited / 2009 Boxster S
Toning down the electric steering pump possible?
Would be awesome if we could reduce the power sent to the electric steering pump to reduce assist, and gain more weight/feedback - anyone know if this is possible? Dont know enough about electronics to know where to start..
kertong is offline   Reply With Quote
Old 02-06-2013, 12:43 AM   #2
ahausheer
Re-member
Drives: Toyota camry
Could you just remove the power steering pump? Is there a power steering pump? I think the electronic assist is not hackable like the ecu.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-06-2013, 12:50 AM   #3
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
there is no 'pump' since its essentially a manual rack with a moderately sized electric motor attached to it. If you rip apart the under-dash area I bet you could figure out how to depower the rack if you were so inclined.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 02-06-2013, 07:02 AM   #4
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Put some wider rims/tires on it--that'll get it done for you. I honestly think they tuned the steering w/ that in mind.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 02-06-2013, 07:22 AM   #5
a2cpc
Drives: WRX
When you find the motor, take a little fluid out.
a2cpc is offline   Reply With Quote
Old 02-06-2013, 07:23 AM   #6
Giacomo
Drives: BRZ Limited in World Rally Blue
You would have to change the gain on the spool valve to change the feel, more than likely. Changing the power steering pump power will probably only change the saturation pressure.
Giacomo is offline   Reply With Quote
Old 02-06-2013, 07:59 AM   #7
Skurj
Drives: SOLD...
In the yaris you can just pull the fuse for the electric steering motor...
Maybe possible in BRZ/FRS?
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 02-06-2013, 08:17 AM   #8
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I agree! I love the way my car feels/handles with the wider rims and tires. I have way more grip, better steering feel, and can still get the car sideways when I feel the urge. Don't mess with the electric steering assist..
chadstyle is offline   Reply With Quote
Old 02-06-2013, 09:12 AM   #9
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
Just for reference, what size tires and rims do you have?
AlexTheGreek is offline   Reply With Quote
Old 02-06-2013, 10:05 AM   #10
markitect
Drives: Scion FRS
Here you go, havn't tested on the FRS, but I know it works on other Toyotas.
http://www.autospeed.com/cms/article.html?&A=111532
markitect is offline   Reply With Quote
Old 02-06-2013, 11:32 AM   #11
Turbowned
Turbowned's Avatar
I think wider/stickier tires will help increase steering effort. Comparatively, when I switch from wide, sticky summer tires to skinny snows with my MR2 (manual steering with Quaife quick ratio rack), the steering effort decreases drastically. Almost to the point that I wish my car had stock tires on it again, but then I remember that I'm not a sissy.
Old 02-06-2013, 11:40 AM   #12
kertong
Thank you!! (How do I thank people for posts here, am I too new to be able to do so?)
This was the bit I had read previously that gave me hope for depowering the assist. Back when I had the MR-S, I could not do this as they used hydraulic racks with fluid-assist - unplugging the pump meant you were just squishing the fluid yourself.
If you have a true manual rack, turning off or detuning assist would give it quite a bit more feedback and weight, much much closer to the lotus elise or 1991-1993 NSX's steering feel.
Don't get me wrong - I LOVE the feel of the steering in this car. But as I feel it reading the road and giving me messages, I can sense quite a bit of potential in it that is being muted by the electric assist.
It is SO close, though. Closest steering feel I've felt to the manual Lotus Elise was the 987.1 boxster / cayman S cars, and the BRZ comes amazingly close to those p-cars. The only difference being the weight/effort required to turn the wheel.
Old 02-06-2013, 11:41 AM   #13
kertong
:O :O fantastic, thank you so much!
Old 02-06-2013, 02:17 PM   #14
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
It's probably the steering rack bushings.
Get some of these!
post_break is offline   Reply With Quote
Electric FR-S by TGMY Surok Scion FR-S / Toyota 86 GT86 General Forum 39 12-03-2012 03:43 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
Electric Cars? Godzpeed Other Vehicles & General Automotive Discussions 16 06-25-2012 09:45 AM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
