Drives: Some rust bucket
Camber bolt torque spec
I received the SPC 81280 16mm OEM finish camber bolts. The instructions say to torque it to 83 lb-ft. I can't find the exact torque specs for the OEM bolt, but I believe it's well over 100 lb-ft. The same exact SPC camber bolt but in traditional zinc finish requires over 100 lb-ft as well.
Is it safe to torque these SPC OEM finished bolts lower than the OEM specs? Last edited by ayau; 01-08-2013 at 10:02 AM. |
I received the following email from SPC regarding the torque specs of their OEM finished bolt.
ayau, We changed the material on the camber bolts due to increasing requirements from the auto manufacturers that we supply to. The new OEM finish is significantly more durable against corrosion due to salt spray. Additionally, the new finish has less friction so less torque is needed on the bolt to get the same clamping load. |
Drives: '13 BRZ Ltd WRB
My Eibach bolts also required a lower torque rating, no biggie. The torque is set to get the bolt to stretch the proper amount, so it's more about the bolt/material than what you're bolting it to.
If you want to safe guard against the bolt slipping put some paint under the heads of the nut and bolt. This will lock it into place when dry.
Tony |
| Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
| Torque spec for lug nuts | wrxneffect | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 09-06-2016 08:39 PM |
| Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
