Old 06-23-2015, 11:00 PM   #1
TCR
Drives: 2013 Toyota 86 GT
Data logging dashes
Hi Guys,
I have a 2013 Toyota GT that I'm setting up as a weekend track car. I've always had a passing interest in data logging and have toyed briefly with one or two before. I'd also like to monitor some of the car's vitals whilst on track, so rather than invest in 3 guages, an oil pressure warning light, a shift light, a data logger and a dash of some description, I'm looking for one unit to do it all. I'd also like to able to set alarms for different parameters such as low oil pressure, high water and oil temp etc.
I know AIM do a couple of models as well as Haltech, Racepak etc, but I'm new to these sort of units, so looking on some advice on which units would do what I'm looking for, and work with our cars.
Thanks.
TCR is offline   Reply With Quote
Old 06-23-2015, 11:53 PM   #2
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I have no experience with all-in-one solutions but I did have a Race-Technology data logger (DL-1) that I particularly liked and used for logging autocross runs with my Tacoma...
They do make a stand alone, all-in-one dash:
http://www.race-technology.com/dash2_pro_2_31358.html
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 06-24-2015, 12:25 AM   #3
TCR
Funnily enough, I use to have a DL1 as well in my STi race car, but never really got around to using it to it's full potential, as I sold the car.
Race Technology seem to make a pretty good product, and I would consider one of their "all in one packages" if the price was right.
As I'm fairly new to this, I suppose the other thing to consider would be local support or at least a forum such as this for support.
The Following User Says Thank You to TCR For This Useful Post:
CSG Mike (06-24-2015)
Old 06-24-2015, 03:32 AM   #4
My experience is limited to Motec, Racepak, and AIM. Hopefully someone else can chime in...
@Element Tuning?
Old 06-24-2015, 12:32 PM   #5
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Take a look at the ArcFlash Dash: http://www.arcflashed.com/collection...s/digital-dash
I have one in my BRZ, wired up to CAN and a few direct sensor connections. I don't have oil pressure but there is a thread here on how to add one and you can wire it into the Dash.
If you don't need hardwired sensors, then try CMS Lap Timer for iOS and Android and get a BT OBD2 dongle to connect to your car. Has alerts, logging, analysis, etc.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
FrX (06-24-2015)
Old 06-24-2015, 01:25 PM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Race Technology is one of the best. I had the Race-Technology data logger (DL-1) and dash 2 display in my Minibusa. Very professional complete unit. It will do anything you want.
Lunatic is offline   Reply With Quote
Old 06-24-2015, 02:24 PM   #7
stugray
Drives: 2013 GBS BRZ Limited
I built my own.
The datalogger itself is Arduino based and interacts with an Innovate AFR (LC-1) and thermocouple reader (TC-4).
It logsBattery voltage, AFR, 2XEGTs, 2X CHTs, throttle position, oil temp, oil press, fuel press, tach, and a couple spare channels.
If I dont hook the droid phone up to usb, the DL logs to a internal sdcard.
It also can turn on the DASH warning light if any parameters get out of range.
It has a shift light output as well.
If I hook up the droid phone, I can view or plot the data in real time.
This is all on a 71 vintage race car :-)
ANY droid device will work as the display, so I could embed my 2 year old 10" tablet in the dash and that would.
Do any of those other dashes have touchscreens? :-)
The Following 3 Users Say Thank You to stugray For This Useful Post:
Astroboy (06-29-2015), Racecomp Engineering (06-24-2015), robot (08-01-2015)
Old 06-24-2015, 07:41 PM   #8
TCR
Being fairly new to it all, the more simple the better, so I don't think I'll be building anything from scratch
The more I think about it, I really don't need a full dash as such, as the car still has it's original dash and is registered and driven on the road frequently at this stage. However, I would like a display that incorporates, some shift lights, lap timing (maybe predictive as well), displays oil pressure, oil temp and water temp, and has well lit alarms for those three.
On that basis something like the Race Technology Dash 4 and a DL1 might do the trick. I also like that you can integrate GoPro video as well, as I already own a heap of GoPro gear.
Old 06-30-2015, 07:12 AM   #9
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We did a lot of research before choosing a setup that will be required for Spec86 Cup racing here in the US. In the end it came down to:
Race-Technologies
AIM
We liked the RT setup as you didn't need to get the dash right off the bat and the setup was expandable as your needs arose. The issue was that it wasn't widely used and we weren't positive that their tech support would necessarily be available when we needed it (namely weekends when we are at the track etc).
AIM has a huge following here in the US and at any given race weekend there are at least 10-20+ guys using the AIM stuff on their cars so peer support is there and then contacting AIM is also easy. For our purposes where we will be using the AIM data for compliance the AIM corp support to help us setup quick and easy analysis tools is invaluable.
-mike
AZP Installs is offline   Reply With Quote
Old 07-01-2015, 10:48 PM   #10
TCR
Yeah, unfortunately I'm in the same boat in regards to support for RT stuff here in Australia. There is a local distributor for AIM here, and he's occasionally at the track, so that could be a bonus.
In saying that the RT Dash2Pro does everything I need, including integration of my GoPro camera, and is $500 cheaper than the MXL2.
Old 07-31-2015, 02:50 PM   #11
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
I realize I'm horribly late to the party, but I'd definitely cast my vote for the Aim units. I used an RT Dash2 in college and was not impressed. It was somewhat glitchy (although this was a while back so we'll assume they fixed it) but customer support was non-existent. There was no one stateside to call, and I never got any replies back from customer support.
Jake
GSpeed is offline   Reply With Quote
Old 08-01-2015, 01:42 AM   #12
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
I built my own.
Do you have source code and such in a public repository?
robot is offline   Reply With Quote
Data logging for noobs - OFT Shad0ez Software Tuning 18 11-07-2016 07:20 PM
best data logging options canadaRS1.0 Software Tuning 2 04-21-2015 05:25 PM
Cannot Read Data Logging From OFT yoonjin Software Tuning 15 12-09-2014 06:53 PM
school me on data logging fatoni Tracking / Autocross / HPDE / Drifting 11 01-09-2014 09:54 PM
Toyota Data Logging CAN for GT6 Luckrider Software Tuning 1 11-23-2013 02:03 PM
