Old 07-08-2014, 12:31 AM   #1
yoonjin
Drives: 86
Cannot Read Data Logging From OFT
I try to get data log for my MAF Scaling,
But OpenFlash Manager does not respond when I try to read log.
Other features are all fine. Only data logging tab is the problem.
How can I fix it????
Since I bought OFT, reading log data has not worked at all.
I've tried administrator mode, win7, xp and other computers.
Everything i've tried cannot solve it.
yoonjin is offline   Reply With Quote
Old 07-08-2014, 12:38 AM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Can't say I've seen that problem before. Do you have another computer that you an try? Doesn't matter if it's a desktop of laptop.
Old 07-08-2014, 12:52 AM   #3
yoonjin
Drives: 86
I tried Win8 Desktop, laptop and Win7 Laptop...
I think I should try with 32-bit processor
Old 07-08-2014, 02:03 AM   #4
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
32bit shouldn't make a difference. I run 64bit Win7 and have zero issues. Maybe try right-clicking the OFT manager icon, and 'running as administrator'.
*edit: nvm, just seen you tried that. hmm.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-08-2014, 02:23 AM   #5
steve99
Are you trying to read old log, if so log format may be different between when log was taken and the updated ofm 1.10.
plug oft into car and take new log this will erase old log and take new log in correct format.
other than that out of ideas :-)
Old 07-08-2014, 06:29 AM   #6
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
What if you try setting your computer to US/English. Maybe it's a localization problem?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-08-2014, 12:42 PM   #7
Shiv@Openflash
Drives: 2013 FRS
Are you sure you have a log file saved on the oft? Make sure you press Start and then Stop. At which time the OFT will give you a message saying that the csv file was saved.
Old 07-08-2014, 09:03 PM   #8
wparsons
wparsons's Avatar
Looks like the computer is running in a Korean language, is that supported by OFT with the template?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
steve99 (07-09-2014)
Old 07-12-2014, 05:33 AM   #9
makinen
makinen's Avatar
Drives: Toyota 86
Several Korean members have been using well with Korean Windows.
Basically recent OSes do not have difference between languages in theory. All just use unicodes.
makinen is offline   Reply With Quote
Old 12-08-2014, 06:27 PM   #10
Spartiduck
Drives: 2013 Subaru BRZ limited 2.0l
Running Windows 8.1, Also cannot access data logging log,
All other options work great. just would like to see the data logging log. I tried several times.
Spartiduck is offline   Reply With Quote
Old 12-08-2014, 06:51 PM   #11
Shiv@Openflash
Drives: 2013 FRS
There is a formatting bug in the latest version of OF Manager. It only effects Windows 8.x users. It should be fixed within the next 24hrs. Until then you can access datalogging by just pressing the TAB button twice and then press Enter. Same thing has just clicking on the READ button which is now hidden.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Spartiduck (12-08-2014)
Old 12-08-2014, 06:57 PM   #12
Spartiduck
Thanks!
Old 12-09-2014, 02:28 PM   #13
Shiv@Openflash
Drives: 2013 FRS
hey guys
v1.15.1 is now downloadable: http://openflashtablet.com/Automotiv...ads/index.html
Could you windows 8 guys confirm that the formatting issue is solved? Looks good on this end.
cheers,
shiv
Old 12-09-2014, 03:50 PM   #14
Spartiduck
Originally Posted by Shiv@Openflash View Post
hey guys
cheers,
shiv
Windows 8 thinks its a suspicious file and you need to run anyway.
It installs in a new directory without the ability to install anywhere else.
Formatting Looks good.
data log, oft, open flash tablet
OFT Data Logging and Exhaust Leak alexand3r Software Tuning 6 08-02-2019 07:02 PM
Data logging for noobs - OFT Shad0ez Software Tuning 18 11-07-2016 07:20 PM
school me on data logging fatoni Tracking / Autocross / HPDE / Drifting 11 01-09-2014 09:54 PM
Toyota Data Logging CAN for GT6 Luckrider Software Tuning 1 11-23-2013 02:03 PM
Onboard Data Logging for XCross/Trackdays brzmaybe Tracking / Autocross / HPDE / Drifting 16 06-15-2012 07:03 AM
