Old 06-22-2015, 08:57 PM   #1
86_PWR
Drives: 2015 FRS RS 1.0
Quick oft question
I bought the oft a while back when the 1.0 maps were on it. I then updated to the all new 2.0 maps. I havent seen anything for a bit concerning any new maps and was wondering if anyone could enlighten me. Are there any new major map updates? Meaning big changes or have there just been minor tweaks; specifically looking for any more power increases. Thanks.
86_PWR is offline   Reply With Quote
Old 06-22-2015, 09:09 PM   #2
D_Thissen
D_Thissen's Avatar
I believe if you open the zip file, there is a document that has all the revisions for each map from v1.xx to v2.xx. @Shiv@Openflash
Old 06-22-2015, 09:30 PM   #3
PMok
Codename: Stitch
PMok's Avatar
if you are updated to somewhere between v2.03 - v2.06 then there are no major changes -- the only differences has been increased compatibility with various foreign ECUs.
The Following User Says Thank You to PMok For This Useful Post:
Shiv@Openflash (06-25-2015)
Old 06-23-2015, 06:15 PM   #4
86_PWR
Ok thanks
Old 06-25-2015, 12:12 AM   #5
D_Thissen
D_Thissen's Avatar
OP if it's ok, I'm going to steal you thread for a second. I have a few quick questions.
1. Why is their a folder named v2.07xml(use these for edit)?
2. When I tried to open the rom AO1C.xml from that folder, rom raider gives me an error. (ECU definition)
3. I noticed my original stock rom (AO1C)that I downloaded from my OFT to save on my computer ends in I believe .ori. Is that normal?
4. If I wanted to disable the cold start valve overlap on my V2.0x Stage 1 tune, do I modify that specific '.bin' and safe it as a new file name? Then load that onto the OFT?
Sorry if I'm dumb but I figured I'd ask before I brick something.
Thanks!
Old 06-25-2015, 02:12 PM   #6
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks!
I think I just talked to you on the phone. So I'll try to help a bit more here so it's in writing for you to reference.
1) The XML folder includes all the current XML files used for all the current off-the-shelf maps
2) You are getting an error when you try to open the stock ROM because there are no XMLs added to the RomRaider Definition File manager. You'll need to go through that to add your XML file to RomRaider. So this means you will need to locate the XML folder you downloaded from the website and then navigate through the RomRaider Definition File manager to find it, select the desired XML and then press Apply and then Save. From that point onwards you should be able to open and view your ROM.
3) Yes, all original files from the OFT are saved in .ori format. Functionality it is the same as .bin files. You can even change ".ori" to ".bin" to match the format of all the other OTS map files.
4) Yes, that is exactly correct.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
D_Thissen (06-25-2015)
Old 06-25-2015, 03:12 PM   #7
D_Thissen
D_Thissen's Avatar
Thanks @Shiv@Openflash !
Nope wasn't me who called but I appreciate you getting back to me so quickly. I might have to bug you in the future for an E-Tune
Cheers!
Dan
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 06-25-2015, 04:35 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Cheers!
Dan
That's funny because the person i was talking to on the phone this morning was asking the same exact questions as you!
Old 06-25-2015, 05:05 PM   #9
D_Thissen
D_Thissen's Avatar
Hahaha. Well great minds do think alike
Quick Question JG Scion FR-S / Toyota 86 GT86 General Forum 1 06-14-2015 06:14 PM
Quick Question trsiidno Forced Induction 7 01-09-2015 09:48 AM
Quick Question BRZUK Scion FR-S / Toyota 86 GT86 General Forum 11 11-07-2014 10:48 PM
New guy with a quick question Bullnettles Engine, Exhaust, Transmission 28 05-09-2013 12:03 AM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 11:02 AM
