Old 06-20-2015, 05:28 PM   #1
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Clutch for 350-400WHP?
After talking with a local tuner who has done several BRZ's, he estimates my power for daily driving at around 350 wheel HP and 400+ for track use. He recommended the stage 2 clutch with flywheel from Exedy and noted that not much else held up to the torque of these engines.
Does anyone else have experience with a good clutch for BRZ's in this power range?
I've also been looking at the TRD lightweight flywheel and racing clutch for the BRZ. Has anyone run this before?
My main concern is that I don't want to be changing clutch disks and getting things resurfaced every 10k miles. I'd like to make it to at least 30k.
TurboBRZ is offline   Reply With Quote
Old 06-20-2015, 05:30 PM   #2
raven1231
A lot of people on the forum use the exedy. I have always used them in my builds.
Old 06-20-2015, 08:48 PM   #3
TurboBRZ
TurboBRZ's Avatar
How long do you see them lasting typically? I wouldn't be surprised if Exedy made the TRD clutch as it looks the same and they do make a lot of OEM clutches.
Old 06-20-2015, 10:06 PM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
Check out Southbend clutch.
Fastbrew is offline   Reply With Quote
Old 06-20-2015, 11:03 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
ACT with HD pressure plate, sprung 6 puck
Old 06-21-2015, 08:32 AM   #6
TurboBRZ
TurboBRZ's Avatar
What kind of life are you guys seeing out of your clutches? Also what kind of power are you making? Once my car is done I think it would be fun to join your group Sportsguy!
Old 06-21-2015, 11:27 AM   #7
Sportsguy83
Drives: Limited BRZ
I've owned Exedy Twin Disk, Exedy Stage 2, FX350, FX400 and ACT 6 puck with HD pressure plate.
Exedy TD: obviously holds whatever you throw at it. Pedal effort is really REALLY high compared to all others. Even after break in, religiously per Exedy guidelines, there was still 20% of the time coming from a stop, where the clutch would INSTANTLY full grab, and you either chirped tires or stalled. No way around it and it was completely random. Not fun to drive at all anywhere.
FX350/400: Fairly easy to drive, pedal effort not too bad. I changed it because after a while, when the car warmed up it started to get hard to engage gears. Other people reported similar behavior.
Exedy Stage 2: This clutch was a dream come true to drive. I got it after Ptuning had been using it on their 400+ WHP car with success, even though its rated for around 215 WTQ. The problem with it was that a few people (including me), started experiencing locking out of gear issues. Coming from a stop, it was sometimes nearly impossible to get the car into first gear. Seemed like the cultch disk was not moving up and down the shaft. Exedy was great with me, and replaced it under warranty with a different version of the Stage 2 clutch (3 puck version). The person I sold it to, has had no problems with this new version.
ACT 6 puck with HD pressure plate: This clutch is fairly easy to drive, pedal effort is less than the FX400, holds pretty good power too. I avoided getting an ACT because I had friend's with bad experiences with them. I ended up getting it because I had no other choice and it ended up being a great buy. I can do a lot of 500 whp 383 wtq and the clutch holds good (it's rated for 345 Flywheel torque). It can get spongy if I do a few pulls at 550 whp 471 wtq, but that's completely understandable and far beyond its rating.
The ACT with Xtreme pressure plate requires a considerable amount of more pedal effort than the ACT with HD pressure plate. I would not get the xtreme pressure plate (bumps the rating to 450 flywheel torque).
Happy boosting!
Old 07-04-2015, 07:33 PM   #8
akash_
Drives: 2013 FR-S White
im a clutch master fan boy through my experience (mr2 turbo 312 whp)
act -great but not on the durable side imo
exedy (single disc)- same as act
cm- has it all: factory feel on the foot, racing clutch grab and can take any amount of punishment
akash_ is offline   Reply With Quote
Old 07-04-2015, 08:33 PM   #9
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
OS Giken makes a clutch for FA20.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-14-2015, 11:57 AM   #10
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm considering South Bend clutches as well, but their price went up significantly in the past several months.
kmbkk is offline   Reply With Quote
Old 07-14-2015, 12:38 PM   #11
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Happy boosting!
Why does every1 say that? My act extreme with full face is cake to drive. Not too hard but u can feel it perfectly like a porsche
lbroskee is offline   Reply With Quote
Old 07-14-2015, 12:40 PM   #12
Sportsguy83
Drives: Limited BRZ
I bet you got mistakenly sold the HD PP instead of the Extreme
That is what happened to me. I bought the Extreme, but what I actually received was the HD. After loosing my mind, getting mad and demanding a refund, I tried the Extreme PP pedal and it's really noticeably and considerably harder than the HD. Decided to stay with the HD.
The HD is holding fine 383 WTQ and some pulls at 471 WTQ, so won't be looking to get an upgraded clutch anytime soon.
Old 07-14-2015, 12:43 PM   #13
lbroskee
lbroskee's Avatar
NOPE. Packaging even said extreme. Every1 tells me it's super heavy but I don't get it
Old 07-14-2015, 12:52 PM   #14
Sportsguy83
Drives: Limited BRZ
Hve you tried someone with the HD one? I only tried it in Alex Bizcayne car and it was right after installing the HD and the difference between both (trying one right after the other) was huge.
Joining the 400whp club Mild2Wild Forced Induction 19 11-01-2015 01:33 PM
Aiming for 400whp Senna Forced Induction 38 12-03-2012 12:03 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
