Old 06-20-2015, 03:23 AM   #1
notout86
Drives: GTS 86 auto
steering mod
Everyone raves about our steering & I agree but having come from a variable ratio system I appreciate the advantage. Straight ahead is fine but often I cannot turn as sharply as I would like without re-positioning my hands first.
Has anyone explored the idea e.g. swapping to the VW Golf GTI system?
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 06-20-2015, 07:36 AM   #2
KAR
Drives: Whiteout 6spd
Someone makes quick racks.. Can be made for whatever car.. I like the way my evo steering feels, and I wanted the same for my BH legacy.. I can't remember the company name but they made one to directly fit my legacy..
KAR is offline   Reply With Quote
The Following User Says Thank You to KAR For This Useful Post:
notout86 (06-20-2015)
Old 06-20-2015, 01:23 PM   #3
KoolBRZ
KoolBRZ's Avatar
Originally Posted by notout86 View Post
Everyone raves about our steering & I agree but having come from a variable ratio system I appreciate the advantage. Often I cannot turn as sharply as I would like without re-positioning my hands first.
A power-assisted rack might be tricky, since ours are electric and most others are hydraulic. Since our steering is assisted up on the column, a manual steering rack could work. The VSC could be affected though, and that wouldn't be easy to fix. You would definitely have to reset the VSC after getting a professional alignment, since the electric assist would keep trying to center what it thinks is the center. A caster adjustment can also make the steering tighter in the middle and looser towards the ends. There is a no-lift caster kit available that would be much cheaper, easier, and less risky, than replacing the rack.
The Following User Says Thank You to KoolBRZ For This Useful Post:
Old 06-20-2015, 08:49 PM   #4
notout86
Drives: GTS 86 auto
Thanks folks. I had a feeling the electric assist might be a problem and had not thought of the VSC complication. I will check the caster idea.
Old 06-22-2015, 10:34 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
You might find some drift front knuckles that increase the ratio as well as the lock. That said i am fairly sure we have a variable ratio rack already.
1974 TA22 Celica
2013 86 GT
steering sensor puma Cosmetic Modification (Interior/Exterior/Lighting) 7 03-07-2019 12:01 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
The e-steering regal Scion FR-S / Toyota 86 GT86 General Forum 12 06-29-2012 01:23 PM
