Old 05-04-2014, 01:19 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Subaru camber bolt question
I installed a set of Eibach Pro-Kit springs a few weeks ago and I bought a set of these bolts on Friday. I am due for an alignment once I have time for an appointment. My question is, what is the optimal front camber numbers for a DD? I do want better performance but at the same time, I drive about 100 miles\day commuting to work and am concerned about even tire wear.
I watched a DIY install video that someone posted, as well as reading other topics, and they say to push the hub all the way up when tightening the camber bolt to give max negative camber. This is where I am confused. You are already getting negative camber by lowering the car, and camber 'kits' are supposed to correct this, right? So why are people saying to make the camber issue even worse when installing these bolts? Doing the opposite of what I thought camber kits are supposed to correct? Is this aimed at people who only track their cars and\or don't care about tire wear?
Old 05-04-2014, 01:40 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
Also the "stance" and "fitment" crowd, that adds negative camber to bring the top of the tire/wheel under the fender to be "flush".
Gunman is offline   Reply With Quote
Old 05-04-2014, 01:48 PM   #3
Racecomp Engineering
From the factory, these cars have very very little camber up front.
When you lower the car you do get a little more but not much.
These bolts get you a little more camber...enough to make a solid difference in handling, but not enough to worry about tire wear even when maxed out. Some will expect better and more even tire wear with the bolts maxed out.
- Andy
Old 05-04-2014, 02:25 PM   #4
B-R-Z
B-R-Z's Avatar
So are these bolts useless for me since I would like a stock equivalent camber for good tire wear? Or can they be used to correct whatever my suspension and wheel upgrade did to my original camber?
Old 05-04-2014, 02:31 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
They can adjust + or - in terms of camber, so if you really want 0 camber yes it could do that. Most people buy them to increase camber because it really doesn't change much in front just from lowering. Instead of pushing, just pull the top of the hub out. An alignment shop should know how to do this and should be the ones doing this as positive camber is even worse. However, anything less than -1.5/-2 really won't give you excess tire wear. It is toe that kills tires.
Old 05-04-2014, 02:38 PM   #6
B-R-Z
B-R-Z's Avatar
Ok, so I might not even bother with these bolts. I will give them to the shop to use only if needed.
Old 05-04-2014, 07:21 PM   #7
vroom4
Put them on and slam full negative. You already have them might as well
vroom4 is offline   Reply With Quote
Old 05-04-2014, 08:12 PM   #8
B-R-Z
B-R-Z's Avatar
I'm not going for the slammed look, I'm for the functional clean look.
Old 05-04-2014, 08:21 PM   #9
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Another member runs these and he got less than -0.5 using these. the SPC's will get you a solid -1.0* out front. Maybe more. But, they're also not quite as beefy as the Subaru camber bolts.
Old 05-04-2014, 08:48 PM   #10
ayau
Drives: Some rust bucket
Depends on how your alignment guy installed them. Mine was able to get me -1.5 on stock suspension.
Back to the original question. If you're concerned with retaining the OEM alignment specs, you should be more concerned about the rear camber. As you lower the car, the rear will gain more camber at a faster rate than the front. On Eibach Pro Kit springs, I'm guessing you'll get about -1.5 +/- 0.5 degrees in the rear. The front will most likely be around -0.5 +/- 0.5 degrees.
The car will tend to understeer more at the limit because the rear has more negative camber/grip. You can add some grip back to the front by adding more negative camber at the front.
Old 05-04-2014, 09:13 PM   #11
wparsons
wparsons's Avatar
Ask yourself a couple questions (or go to a proper performance alignment shop).
1) Have you done any, or do you plan to do any track or autoslalom?
2) How is the wear on the outside of the tire? If you're wearing onto the shoulder too much and you've already bumped up the tire pressure then you'll want more negative camber for sure.
If it is strictly a DD and/or you're not wearing onto the should of the front tires, then fall back on the OEM settings.
Mine up front with sticky tires and not enough camber (at 38psi cold):
flickr
Old 05-04-2014, 11:34 PM   #12
solidONE
solidONE's Avatar
I think I got about 1.2-1.3 with one set of bolts iirc. That's with the adjustment done with the car raised. My alignment guy *points to self* does not have ramps so 'he' cannot do adjustments with the wheels loaded. Maybe I'll talk his cheap ass in to getting some ramps soon.
The Following User Says Thank You to solidONE For This Useful Post:
wparsons (05-05-2014)
Old 05-05-2014, 08:01 AM   #13
wparsons
wparsons's Avatar
^^ You could always just use jack stands supporting the suspension, but you want to be VERY careful when setting the car down on them that the suspension movement isn't trying to slide or tip the jack stands.
It's probably not ideal, but that's how I torqued my LCA pivot bolts after installing springs. I did keep the floor jack supporting the subframe (either front or back depending on which end) enough that if a stand did slide out the car wasn't going anywhere at all.
flickr
Old 05-05-2014, 07:19 PM   #14
solidONE
solidONE's Avatar
I actually loaded the knuckles using a wood block and floor jack when I tried to max out the adjustment. I think with the wheel fully loaded while raised on some ramps and a couple of 'heavy set' people sitting in the car is likely the best way to get maximum adjustment.
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
Camber bolt bhbnuckle CANADA 3 04-16-2014 08:05 PM
Camber bolt help oofie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-22-2013 01:36 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
