Old 06-17-2015, 08:49 PM   #1
HGaudio
Drives: 13' Scion FRS
What size tire should I run?
I'm sure there is a thread about this but I'm pretty new to the forums and needed some advice. last week I purchased a set of Avid 1 AV20's for my FRS. I went with a 18x8/9.5 setup. Anyway, I'm pretty knew to stretching tires so I needed some advice. I had a extra pair of Nexen N5000 tires that are 225/40 that I planned on putting on the back but I didnt know what tire to run up front. The smallest I could find was 205/40 but I wasnt sure if those would look the same up front on the 18x8's as the 225's on the back. Any advice would be greatly appreciated. thankyou.
HGaudio is offline   Reply With Quote
Old 06-18-2015, 03:20 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Why would you want to stretch your tires? (That's one of the stupidest automotive 'styles' ever.). 225/40 is good on an 8" width. 255/35 would be good on a 9.5" width. Keep in mind that tires are not all made the same though.
Old 06-18-2015, 03:28 PM   #3
8R6
8R6's Avatar
Drives: FRS
are you going to slam your car? are you going to be putting on spacers? are you going to dial in a lot of negative camber all around? those wheels have pretty conservative offsets and combined with anything other than dumping the car, stretched tires would look ridiculous and unnecessary. stretching tires came about to get the wheels fit, not just for the sake of stretching.
8R6 is offline   Reply With Quote
Old 06-18-2015, 03:30 PM   #4
STV3
Señor Member
STV3's Avatar
Size 6.... /thread
STV3 is offline   Reply With Quote
Old 06-18-2015, 05:25 PM   #5
HGaudio
okay so if i put the 225/40 on the front what difference would putting 255/40's on the back make instead of 225/35's?
Old 06-18-2015, 05:51 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
255/40/18 on back would be a LARGE tire.
More importantly, what is your suspension setup? You might be rubbing fenders/springs/struts.
We need to know suspension setup, and offset of your wheels before we can try and tell you which tire may/may not work.
Old 06-18-2015, 06:05 PM   #7
HGaudio
I just ordered tein coilovers & the offest of the wheels are +35 front and +38 rear
Old 06-18-2015, 06:09 PM   #8
gramicci101
Off Topic
Do 225/40 front and 255/35 rear. Those two sizes have very similar outside diameters and are pretty close to the OEM outside diameter.
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
what tire size? Boofneenee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2015 11:40 AM
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 12:03 AM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
