Tuning After Intake/Exhaust Install
Hello all!
I'm going to be installing a TRD Intake and a Perrin 2.5" Resonated CBE pretty soon, and I'm curious about something. Is it recommended to get your ECU tuned after such an installation, simple as it is, or will the ECU adjust itself accordingly? I've seen recommendations for ECU tuning after turbo/SC installs of course, but not really for simple intake/exhaust setups. Appreciate your input. Sorry is this is so easy. Thanks! |
I wouldn't worry about it unless you get a header. Gains will be minimal either way and it's completely safe to run without a tune.
#3 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | MJones_RB (06-16-2015) |
Do you have to tune it? No not really for a TRD intake & cat back exhaust. Will you gain any power from bolting them on? Possibly, but minimal if anything at all. The throttle response might be slightly more crisp due to the TRD intake shifting the engine load under low load slightly advancing timing. Most of the gains you "feel" may be during the learning process and once the ecu neutralizes the gains may go away / stay. A lot of bolt on dynos show the best pull out of the car after reseting the ECU and letting it lean out / advance timing before any learning has started. So a lot of bolt on dyno's are skewed a bit... I have seen very few dyno's of a car with learning for a few tanks of fuel, then swapping parts, allowing learning for a few tanks and re-dyno with similar weather.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | MJones_RB (06-16-2015) |
Thanks! I have noticed that the car is beginning to "learn" my driving habits, adjusting itself, etc. I have even noticed the average mpg has changed since I started driving the car. Interesting technology these days. Much more than my old '96 Integra. Now if I could just figure out what that "shudder" is during idle...
#6 | |
Get an OFT and have some fun with your car for under $500. You'll learn a lot. Potentially blow your engine up (just kidding- kind of).. and are able to run E85 right off the bat. Best bang for your buck, imo. |
| The Following User Says Thank You to Koa For This Useful Post: | MJones_RB (06-16-2015) |
#7 | |
| Basic Bolt on mods intake, exhaust tuning guide | steve99 | Engine, Exhaust, Transmission | 204 | 09-12-2022 08:06 PM |
| Innovate SC Install, Testing & Tuning | Xero-Limit | Forced Induction | 231 | 01-23-2015 12:32 PM |
| **Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 11:18 AM |
| bay area shops for exhaust and intake install? | vujosephv | Northern California | 11 | 02-09-2013 11:40 AM |
| JRP's Injen intake/Exhaust install in part #2 | Stav | Engine, Exhaust, Transmission | 2 | 10-18-2012 12:57 PM |
