86WORX
Old 07-09-2013, 02:27 PM   #1
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Innovate SC Install, Testing & Tuning
The kits showed up, and after catching up we went to put one in in the after hours. Instructions are great, but there's a few little tidbits to keep in mind. Here's the saga in pictures.
Some notes:
Pry the top "lid" as pictured. This keeps the tabs from bending in the back.
The picture in the manual is not very clear about which hose gets the extension hose. The one going to the intake is the one that gets the one with the barb. The other one routes back to the SC.
Make sure the fuel hoses and lines are under the blower before you bolt it down. We did have to file the alternator for about 30 seconds to remove .5mm of material. So have a file. DO NOT attempt to skip this if needed.
Check for fuel leaks IMMEDIATELY. Though the o-rings at the top of the injectors usually can be re-used, despite taking all the precautions and being gentle we had a nice spray. Car has 11k on it. $12 each from the dealer, or you can chance it with a generic. Use assembly lube or something similar.
The hood padding as others have said can stay on. It will get the "love bite" from the SC pulley so we left it on.
Tuning wise it took a couple of hours but we have a solid tune now. Going to put it on the dyno this afternoon and see where are are at. I'm pretty sure we'll top 220 on pump gas and stock header/exhaust, but it is hot and muggy out today. Going to bring some E85 jugs to test with if we have time!
Xero-Limit is offline
The Following 16 Users Say Thank You to Xero-Limit For This Useful Post:
autobrz (07-09-2013), Calum (07-09-2013), chutrain (07-09-2013), cmss2000 (07-10-2013), Dezoris (07-09-2013), ftc~brz (07-09-2013), jamesm (07-09-2013), mines13 (07-09-2013), Pete (07-09-2013), Splat (07-28-2013), sw20kosh (07-09-2013), Touge Factory (07-10-2013), Toyota86.ir (03-09-2016), whataboutbob (07-09-2013), wrxgoose (07-09-2013), xxscaxx (07-09-2013)
Old 07-09-2013, 02:36 PM   #2
Dezoris
Dezoris's Avatar
Did you pull your DI Injectors while in there?
Dezoris is offline
Old 07-09-2013, 02:40 PM   #3
Xero-Limit
Xero-Limit's Avatar
Nope, haven't had the need to but it is simple enough if needed. Honestly this has to be one of the easiest installs on an aftermarket FI system I've done on an import. The hardest part is mounting the SC (have a helper) and double checking hose routing. Now that we got that figured out it should be a one day job.
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
sw20kosh (07-09-2013), whataboutbob (07-09-2013)
Old 07-09-2013, 02:43 PM   #4
sw20kosh
Drives: 2013 Black FR-S
For those installing (and I don't know how important this fitting is) but this guy has come loose after driving the car for a month. Might want to check that it is tight before installing the sc. You cannot tighten it while it is on the car because it cannot rotate fully (it is blocked by manifold casting and other fittings etc).
Is it important that this thing is tightly sealed? It is screwed in there but it moves left to right semi-freely as if it needed 1/2 to 1 more turn. It is pre-sc so it sees vacuum only. Is it maybe supposed to swivel?
sw20kosh is offline
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
ftc~brz (07-09-2013), whataboutbob (07-09-2013), Xero-Limit (07-09-2013)
Old 07-09-2013, 02:45 PM   #5
Dezoris
Dezoris's Avatar
Compared to the Vortech yeah it's a cake walk, but it's not intercooled so that reduces half the install drama.
I have asked for this multiple times but can you post up some of your log info, like IAT, oil temps, coolant temps, ambient temps from your dynos?
One of the main reasons I am waiting to take this on as a project is no one is being forthcoming about this.
With no intercooler and that blower generating heat on the intake manifold, how much temp is it actually generating with the intake charge?
Dezoris is offline
The Following User Says Thank You to Dezoris For This Useful Post:
chadstyle (07-12-2013)
Old 07-09-2013, 02:49 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Looks like a vacuum fitting. I definitely would not want it moving around and possibly allowing a vacuum leak that would be very hard to track down.
King Tut is offline
Old 07-09-2013, 02:50 PM   #7
sw20kosh
This wont answer your question completely but the innovate car running stg 1 registered something like a 133 IAT post-blower on a 100 deg track day. I'll try to find the post.
sw20kosh is offline
Old 07-09-2013, 02:52 PM   #8
swift996
swift996's Avatar
Thanks for the tips. I'm most worried about figuring out the hose routing.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 07-09-2013, 02:53 PM   #9
sw20kosh
Yes it is vacuum. Looks like it connects to the EVAP purge solenoid.
sw20kosh is offline
Old 07-09-2013, 02:57 PM   #10
Xero-Limit
Xero-Limit's Avatar
nothing to worry about. It vacuum as stated above and won't cause a big enough leak to affect tuning if it is just a hair loose.
Old 07-09-2013, 02:57 PM   #11
Xero-Limit
Xero-Limit's Avatar
Not nearly as bad as you think initially. The extensions they provide are awesome. I'll take some high def pictures later on of the final setup after the dyno.
Old 07-09-2013, 03:11 PM   #12
Dezoris
Dezoris's Avatar
I would appreciate it. This is pretty important info to have and would take 5 minutes to post up.
@moto-mike do you have an issue doing this?
Dezoris is offline
Old 07-09-2013, 04:53 PM   #13
sw20kosh
http://www.ft86club.com/forums/showp...&postcount=251
sw20kosh is offline
The Following User Says Thank You to sw20kosh For This Useful Post:
swift996 (07-09-2013)
Old 07-09-2013, 05:08 PM   #14
Xero-Limit
Xero-Limit's Avatar
211 whp on pump in 90 deg weather...
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 11:25 PM
Innovate questions Fast_Freddy Forced Induction 12 07-02-2013 03:27 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
innovate SC for sale kioton32 Forced Induction 4 04-08-2013 12:42 PM
