Old 06-15-2015, 10:07 PM   #1
joshlx
Drives: fr-s
Sound of (possible) dead clutch or a bad transmission? I hope neither
I am taking my car to the dealer tmr but still posting some recordings here in case anyone is interested. I will post updates from dealer if there is any.
I started to hear grinding/rattling sound after I shift into 3rd or 4th gear 2 days ago. It's not during when I put it in gear, but after that when I let off the clutch and get on gas. The sound is very short(about half a second) before settling to smooth engine revs.
Here is the recording(54 seconds long):
https://soundcloud.com/joshlx/shift-...d-and-4th-gear
First part was recorded near the left rear wheel, and the second part was near the air box in the engine bay.
My car has ~24k miles and everything stock. I didn't find any problems with other gears.
I hope it is covered under warranty. Any suggestions are welcome.
joshlx is offline   Reply With Quote
Old 06-16-2015, 01:53 PM   #2
humfrz
UGH! your car sounds like an old Farmall tractor ......
(sorry, just being ornery)
If the sound only lasts a split second, I doubt a tech is going to hear it ....
Does it do it when the transmission is warm .... ??
Check the transmission oil level ... ??
Maybe a transmission oil change would help .... ??
Keep us posted.
humfrz
Old 06-16-2015, 06:37 PM   #3
fistpoint
Drives: Supercharged Golf Cart
The little scratch sound?
Mine also has been doing this since the first few thousand miles. I've been driving manual transmissions for 23 years and have never replaced a clutch, ever. Several of my vehicles have gone well over 165k miles too, still no clutch issues.
Take yours to the dealer, that way I don't have to.
fistpoint is offline   Reply With Quote
Old 06-16-2015, 07:23 PM   #4
tyrantcf
Drives: '16 WRX, CBR1000RR
Same here. Go get us information!
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 06-16-2015, 07:27 PM   #5
tyrantcf
I have been able to essentially eliminate this from occurring though just by being a little more authoritive/deliberate with my shifts.
Old 06-16-2015, 07:48 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just clutch starting to show wear I guess? Do You feel anything on ur feet as u clutch in & out? Lately I can starting to feel my clutch dragging if I take my time @ disengaging the clutch.
Old 06-17-2015, 10:41 PM   #7
joshlx
Drives: fr-s
The dealer couldn't replicate the problem - as you may have expected.
I took a ride with one of their technicians today but couldn't hear the noise either.
The noise may be related to the temperature. It was around 90 when I recorded the sound, but was under 80 when my car was at the dealer.
I'll definitely post more follow ups!
Old 06-18-2015, 12:14 AM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Replace tran oil. Let me see if I can find the thread. Someone had similar issues but it was 2nd-4th gears. They replaced oil. Mine does it if car isn't warm. After driving for like 3-5min it goes away.
Packofcrows is offline   Reply With Quote
Old 06-18-2015, 07:15 PM   #9
aagun
Drives: 86
clutch disc spring wearing
that's normal because that clutch spring can not hold that mach power for long time
i replace mine at 80k km
check here
[ame="https://www.youtube.com/watch?v=RQVqt6Oe_Mc"]gt/86 - frs - brz OEM clutck worn out springs - YouTube[/ame]
aagun is offline   Reply With Quote
Old 06-19-2015, 07:50 AM   #10
fistpoint
Hot or cold weather or engine mine will do it. And as you experienced, it didn't happen when at the dealer...which is why I wanted you to go instead of me
Just make sure it is fully documented so that when/if it becomes a bigger problem after the warrant expires, they should retroactively fix it because you brought up the issue when it was still under warranty.
Old 08-06-2015, 01:58 PM   #11
joshlx
Drives: fr-s
check here
The video is really helpful! The sound resembles what I hear when I shift.
This concerns me because it started happening at ~24k miles(<40k km). I don't know what will happen when my warranty expires.
Old 08-06-2015, 02:00 PM   #12
joshlx
Drives: fr-s
I took my car to the dealer a second time, rode with a technician(I drove) and he heard it too.
However, when I left my car there and the technician drove it himself, he couldn't hear it again - I did tell him it only happens when the weather is hot and the car is warmed up.
I don't know if documenting the noise before warranty expires will help if a problem happens afterwards.
How's yours looking?
Old 08-06-2015, 02:34 PM   #13
Although yours may have something wrong I would just like to point out a couple of things that may mean it doesn't
These shifters are solid linked right to the tranny. This results in a different feel and noises then cable systems used in many modern cars. If not used to them they can seem strange but there is nothing actually wrong with anything and that is just the noises they make.
The lack of sound proofing in these means that you hear every little sound that may exist in other cars but you just never notice. Couple this with the fact that the tranny is sitting a couple of inches from your butt (instead of way ahead of you like in a FWD and the noises get even weirder.
I guess what I am saying is, don't get paranoid about weird noises. If everything is working OK then it probably is OK.
Old 08-06-2015, 02:46 PM   #14
strat61caster
strat61caster's Avatar
Seconding @Tcoat I didn't hear anything alarming in the sound file.
Some people like that this car makes a buncha mechanical noises, reminds them of older sports cars, ahh nostalgia.
ineedyourdiddly
clutch/transmission noise and clunks... slyphen Issues | Warranty | Recalls / TSB 7 06-26-2014 05:18 PM
Transmission Dry Sound & Bogging jjkerr626 Engine, Exhaust, Transmission 3 06-11-2013 12:10 AM
Sound from Clutch KingRohan Issues | Warranty | Recalls / TSB 5 10-17-2012 09:10 PM
Transmission Sound... chipz91 Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2012 01:30 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
