Old 08-21-2012, 03:18 AM   #1
chipz91
chipz91's Avatar
Drives: Toyota Corolla, Asphalt (MT) FR-S
Exclamation Transmission Sound...
I just got my Asphalt MT, a few days ago, first time owning a Manual transmission car. I wanted to ask, can anyone else hear all the gears and clutch moving when driving slow? And I hear something that sounds like I guess I would say, metal rattle? Can anyone here it at low gears/ low speeds as well?
chipz91 is offline   Reply With Quote
Old 08-21-2012, 03:30 AM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Yep, I made a thread about that metal rattling type of sound. all the noise including that sound seem to be normal from what people say.
Sigh-on-Rice is offline   Reply With Quote
Old 08-21-2012, 03:31 AM   #3
whateatsrabbits
whateatsrabbits's Avatar
Drives: 2013"Road scalpel"FR-S MT
Low speeds? Like how low? Your not lugging the engine are you? Lugging would be trying to go up hill below 2000 rpm. Otherwise its pretty normal to hear a slight gear whine while listing very carefully. If your hearing clunks and rattles from the drive line while engaging or disengaging the clutch, you need to practice driving smoother.
NEVER LIFT
Originally Posted by Grishbok View Post
The 86 is a precision car, it does not compensate for driver error, on the road or on the track. This is the kind of car thats created to be the surgeons scalpal of the mass-consumer car world, not a drag car.
whateatsrabbits is offline   Reply With Quote
Old 08-21-2012, 03:36 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
nothing like that on my car.
the only weird sound i hear is the "thug" when you go to 1st gear from a complete stop
86_ZN6 is offline   Reply With Quote
Old 08-21-2012, 03:39 AM   #5
chipz91
chipz91's Avatar
No im not lugging, I can hear it when iim driving around a parking lot. What do you mean from the drive line? I do need to keep practicing to shift smoother, but How..??
Old 08-21-2012, 03:41 AM   #6
whateatsrabbits
You should probably just look at this guys post seems like your problem.
and luckily it has a good sound system
NEVER LIFT
Old 08-21-2012, 03:44 AM   #7
chipz91
chipz91's Avatar
I just did, sounds just about exactly what im hearing and in the same gears too. Im guessing its normal...??... :/?
Old 08-21-2012, 04:17 AM   #8
cRazy604
too nuts
cRazy604's Avatar
Drives: Scion FR-S
i get that too! i thought i was the only one getting that
cRazy604 is offline   Reply With Quote
Old 08-21-2012, 04:30 AM   #9
chipz91
chipz91's Avatar
This transmission is pretty noisy im guessing..??
Old 08-21-2012, 06:15 AM   #10
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
i hear a rattle when its idle parked. nothing threatening so im not too worried
mrlewistan is offline   Reply With Quote
Old 08-21-2012, 08:53 AM   #11
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
This car is just a plethora of sounds and there are cures for all of them. Chang your oil and the engine will quiet down a bit, change your transmission fluid to redline or something like that and change your gear oil to Mobil 1 or something like that and your transmission will be quiet and smoother and won't thud when going into first...Just letting ya know. There are couple of threads on this topic. I would just change your oil after break in and you'll quiet down a lot.
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Hotlava86 is offline   Reply With Quote
Old 08-21-2012, 09:46 AM   #12
MarkMash
MarkMash's Avatar
Drives: Toyota 86
check tranny oil
MarkMash is offline   Reply With Quote
Old 08-21-2012, 01:18 PM   #13
trifenix
Drives: Toyota Tacoma
My friends has a thud in first and also whining under load in some gears.
trifenix is offline   Reply With Quote
Old 08-21-2012, 01:30 PM   #14
Hotlava86
Hotlava86's Avatar
thats normal. change the gear oil and trans fluid and you'll be smooth as can be
noise., transmission sound
Transmission Echo Engine, Exhaust, Transmission 6 08-08-2012 01:38 AM
What transmission? Ess Vee Engine, Exhaust, Transmission 9 06-25-2012 02:56 PM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
