Old 06-10-2015, 02:25 PM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Heat reflecting oil pan idea
We all know of the oil temp issue, so i came up with an idea. Since the headers run so closer to the pan they have to radiate some heat. Yes they are already heat wrapped but maybe adding some sticky heat reflective tape to the front and sides of the pan might help bounce some heat off?
Well it seems to have raised my temps from an average 208ish to 221 calmly driving down the highway on a 88 degree day, idk if its insulating the oil that bad or if the sensor is being affected. I dont recall if i saw the temp sensor on the pan or not but has anyone else tryed this??
IG-Joey_Soul
Old 06-10-2015, 02:32 PM   #2
carlitosway6891
Drives: white out project fr-s
sounds like a double edged sword to me....sure you would be able to reflect some of the radiant heat from the header away from the pan but then you would take away the heat transfer from the oil pan to the natual air surrounding the pan....
maybe the better option would be to get an oil pan that has slightly larger capacity so that there would be more oil to cool down in the pan...i remember seeing a company that offered one.
carlitosway6891 is offline   Reply With Quote
Old 06-10-2015, 03:13 PM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya i think thats what it is doing, maybe a finned pan would be a good idea, like a heat sink
IG-Joey_Soul
Old 06-10-2015, 03:16 PM   #4
We run thermal tape on our oil pan.
Old 06-10-2015, 04:56 PM   #5
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Just where the header is closest, or the whole thing, or some mystical tiger stripe pattern?
BatStig is offline   Reply With Quote
Old 06-10-2015, 04:58 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
What about heat fins? Helps the ambient air wisk away the heat faster?
Old 06-10-2015, 05:04 PM   #7
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
A plate between the pan and the exhaust would be better with a bit of an air gap between it an the pan. If you wanted to take it a step further, now that you have a sort of duct, run a scoop to the front to force air through it and over the pan.
Old 06-10-2015, 05:09 PM   #8
Basically any surface that has heat radiating toward it.
Old 06-10-2015, 07:36 PM   #9
stevesnj
stevesnj's Avatar
Just get an oil cooler.
My 2016 Build thread
Old 06-10-2015, 07:37 PM   #10
celek
Resident Gear Head
celek's Avatar
Oil cooler fixes that as well as a larger pan
celek is offline   Reply With Quote
Old 06-10-2015, 10:45 PM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
thats what i did just the front and sides. less then 50%, you had good results with it?
IG-Joey_Soul
Old 06-11-2015, 03:00 AM   #12
It was more of a "why not" since the Tomei header includes heat wrap...
Old 06-11-2015, 03:38 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
If track cars usually have oil coolers installed anyway, isn't it simpler to not bother with oil pan heat shielding? On daily driven ones oil temps are lower, so less of a reason there too, no?
Old 06-11-2015, 06:51 AM   #14
Grip Ronin
The Mechanic
Grip Ronin's Avatar
I have an oem oil cooler which helps but on track it still gets hot, those external oil coolers are terrible idea for this engine because oil pressure is already low. So finding an alternative solution that doesnt cost me engine bearings in 15k is the idea
IG-Joey_Soul
Heat Shields X Factor Engine, Exhaust, Transmission 4 09-05-2014 03:47 PM
Heat cycled. forwallblakmail Tracking / Autocross / HPDE / Drifting 23 06-25-2014 10:45 PM
Idea for 10 Series Owner, but have no idea how to accomplish. IgnitionGundam Cosmetic Modification (Interior/Exterior/Lighting) 9 10-01-2013 12:29 AM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
