Old 06-17-2012, 11:53 AM   #1
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Will 9.75 wide fit the rear flush?
Just curious. Also, has anyone tried 8.75 in the front with success?
Memphis is offline   Reply With Quote
Old 06-17-2012, 12:01 PM   #2
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Wheels without off-sets won't fit all.
Back to the drawing board I guess.
Old 06-17-2012, 12:04 PM   #3
Memphis
Memphis's Avatar
Old 06-17-2012, 12:57 PM   #4
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Originally Posted by Memphis View Post
+35
http://www.1010tires.com/WheelOffsetCalculator.asp
Stock wheels are 17x7 +48
Just use the calculator and then go outside and measure.
Here is a good place to start:
http://www.ft86club.com/forums/showthread.php?t=7237
denkigrve is offline   Reply With Quote
Old 06-17-2012, 09:45 PM   #5
Memphis
Memphis's Avatar
I saw that but I wish they had more than just those two pictures. I need a picture of the car from behind at the side to see if the wheels are poking out any.
I dont have any means of taking my wheels off as of right now :p
Old 06-17-2012, 09:48 PM   #6
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
I ordered 18x8.5 +44 & 18x9.5 +38 wheels but I won't have them until the 1st or second week of July...if you don't have wheels by then keep an eye on me and I'll make sure to cover all of the dynamic angles for everyone to see.
CoRi J is offline   Reply With Quote
Old 06-17-2012, 09:50 PM   #7
Memphis
Memphis's Avatar
Do you think 9.5 with +35 will be able to turn full radius on our car?
Old 06-17-2012, 09:54 PM   #8
Memphis
Memphis's Avatar
Im also wanting to know if 8.5 +35 will fit the front and still offer full turning radius and not hit the suspension.
Old 06-17-2012, 10:03 PM   #9
CoRi J
Xenogear
nvm I need to correct myself on what I just posted.
like denkigrve said..check out the FR-S in the link he posted because that one has Work wheels on it with the Spec: 18x9.5 +30mm all around..looks like the tire is stretched though on it and not a full fitting tire.
Old 06-17-2012, 10:09 PM   #10
CoRi J
Xenogear
This was from RavSpec on that thread:
Originally Posted by dnjshin0bi
will 18x9.5 +38 all round and 225/40/18 work? no scrub either??
yeah, 18x9.5 +38 will work. Need drop though.
Old 06-17-2012, 11:51 PM   #11
Memphis
Memphis's Avatar
Can you tell if those 9.5 are poking out the front? I know they arent in the back.
Old 06-18-2012, 12:09 AM   #12
CoRi J
Xenogear
They look like they do alittle bit to me...here's another pic I found of some SSR's
post by dnjshin0bi
1. SSR Type F
F&R - 18x9.5 (+?) wrapped in 225/40/18 Front - 245/35/18 Rear
http://www.ft86club.com/forums/showthread.php?p=247412
That's probably as close as you'll find to a fitted 18x9.5 straight ahead pic.
Old 06-18-2012, 12:31 AM   #13
dnjshin0bi
dnjshin0bi's Avatar
Drives: 86 GTS (PW) Manual
post by dnjshin0bi
1. SSR Type F
i think the above picture is running +40 offset. based on 5x114.3mm conversion and on the SSR website. 18x9.5's go to +40
dnjshin0bi is offline   Reply With Quote
Old 06-18-2012, 12:45 AM   #14
leej
Drives: 86 GTS
if its +40 offset in the front it'll leave 23mm less room inside the inner wheel guard... according to @PERRIN_Jeff's post (http://www.ft86club.com/forums/showthread.php?t=6914)
There is about 12-14mm of extra room to move the wheel toward the inside.
it'll scrub like hell.. +30mm offset is a better option seen in the 18x9.5 +30 Kiwami pics somewhere in the forums
leej is offline   Reply With Quote
10.5" wide tire possible?!? Xiao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 10-11-2015 11:00 AM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Why can't the BRZ GT300 or factory BRZ wheels have flush fitment? switchlanez BRZ First-Gen (2012+) — General Topics 43 03-19-2012 12:50 PM
Light, wide wheels with good fitment coyote Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 02-10-2012 04:27 PM
How wide do you think steelies would be OEM? RegisBou Engine, Exhaust, Transmission 23 02-24-2010 03:23 AM
