Old 06-03-2015, 11:40 AM   #1
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Aftermarket steering wheel
Hey guys I wanted to put an aftermarket steering wheel in my car. If I am correct all I will need is a hub adapter, quick release, and the wheel. I want to use a Splash hub adapter as it will allow me to retain the factory clock spring. I will also be using a NRG 2.5 quick release on a Personal wheel. Is this all I need and is there any recommendations for other brands if these are not compatible together?
Old 06-03-2015, 11:53 AM   #2
adamg
Drives: brz
you don't NEED a quick release. those are only for "scene points" unless you having bucket seats with harness's and its hard to get out of your seats which i doubt. but anyways yes splash hub is great, i have one. just make sure your clock spring is centered when you install, otherwise you'll have problems.
Any 6 point wheel will work with that hub
enjoy
adamg is offline   Reply With Quote
Old 06-03-2015, 12:06 PM   #3
NyC Zn6
NyC Zn6's Avatar
enjoy
I never changed my steering wheel on any of my previous cars so I am clueless. You just saved me some money thanks bro
Old 06-03-2015, 12:44 PM   #4
ryoma
ryoma's Avatar
keep in mind that most aftermarket hubs are not designed to crumple when in an impact. the only one that I know of that crumples is the Momo hub. especially the NRG quick releases, they're just straight solid and will not crumple. you're also removing your airbag which is a safety concern. so if by any chance you get into a high speed collision, you will not have your front airbag deploy and your chest/face will slam straight into a steering wheel that will have no give.
I would advise to go with a hub adapter that crumples at the very least.
BTW, quick releases are meant to be used in racing application where you have a tight harness to stop you from slamming into the steering wheel.
DIY Aftermarket Steering Wheel Install kylefrs DIY (Do-It-Yourself) Guides 66 12-11-2022 12:33 AM
Aftermarket Steering Wheel/QR Experiences? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 13 05-22-2020 08:41 PM
Aftermarket steering wheel.. _F-R-S_ Cosmetic Modification (Interior/Exterior/Lighting) 164 04-20-2018 05:29 PM
Aftermarket steering wheel with CC? Yamajee Cosmetic Modification (Interior/Exterior/Lighting) 11 02-16-2014 06:05 AM
Aftermarket steering wheel HELP! Juurian Cosmetic Modification (Interior/Exterior/Lighting) 0 06-03-2013 11:47 PM
