Old 04-05-2015, 04:48 PM   #1
HachiRo
Drives: 2013 White-Out FRS
Aftermarket Steering Wheel/QR Experiences?
Heavily debating (mass-debating ) about going with an aftermarket steering wheel/Quick release combo. Never done that to a car before so I've never had any personal experiences in terms of pros and cons with it.
Anybody here wanna chime in with their experiences using a quick release combo in their FRS or even past cars?
Any bad experiences dealing with accidents, insurance, or the steering wheel somehow coming off while driving? LOL.
HachiRo is offline   Reply With Quote
Old 04-05-2015, 04:58 PM   #2
ryoma
ryoma's Avatar
Don't buy one off ebay that's like $50 if you really want one. Though, I wouldn't recommend a quick release unless race car. Major brands like NRG and Works Bell use ball bearings to lock it in place so I doubt the wheel would randomly loosen off in the middle of driving. I'm not sure how much the Works Bell one weighs, but the NRG one is pretty heavy and extends the extra weight past the steering column which might be a con for some people.
Personally, I like the look of the Sparco quick release and how it uses teeth to mesh instead of bearings. I don't really see how many times you'll be using the quick release in a street car though unless you're a bigger guy that can't fit in the car without moving the steering wheel away (shouldn't be a problem in newer cars due to the adjustability they offer).
Old 04-05-2015, 06:33 PM   #3
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Oh man.
I see riced-out Civics and Eclipses almost every time I go to a grocery store. They always detach the wheel and leave it on their dash.
Because race car.
Just be careful to not be "that guy".
NWFRS is offline   Reply With Quote
Old 04-05-2015, 07:02 PM   #4
Joeyk
Drives: It runs
I like mine. Sparco hub doesn't fit without modification.
Works bell is what I'm going with.
Joeyk is offline   Reply With Quote
Old 04-05-2015, 07:29 PM   #5
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Whats the point in having a quick release steering wheel if your car is not a dedicated track car. You are removing an airbag that can potentially save your life, pretty sure insurance wont like covering someone with a missing airbag. Unless you wear a helmet and a 6 point harness all the time...
brandonblt2 is offline   Reply With Quote
Old 04-05-2015, 08:06 PM   #6
ryoma
ryoma's Avatar
If only there was a more OEM solution for a smaller diameter steering wheel. the stock one still feels a little bit big for me. I had a 280mm Momo in my previous car and that felt perfect. After having a car with an airbag and cruise control, I would rather keep it than changing out for an aftermarket. I think the reason many people want to change out their wheels is to get a size that is closer to their preference and so it doesn't look as ugly.
Old 04-22-2015, 07:42 PM   #7
Blizzard
Drives: '13 FR-S Whiteout
Just don't use the NRG hub! I tried it and you have to remove the clock spring which will disable traction control and ABS. Get the Works Bell hub and a good wheel. I ended up spending well over $1,000 to fix everything I messed up when I took off my clock spring (including new steering angle sensor, another clockspring, and a waste of money on buying the NRG pos hub). Keep the clock spring straight, get resistors for the air bag sensors, and you should be fine. However, steering wheel was by far my dumbest mod yet haha. Over $1,000 to have a different steering wheel when the stock wheel is very good to begin with.
Blizzard is offline   Reply With Quote
Old 04-22-2015, 08:42 PM   #8
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Why not get one that actually retains the airbag if it's a daily driver? I'm using the DAMD wheel and I love it. Noticeably smaller, thicker, and the way it's shaped feels really nice in the hands. Cusco and Prova also offer steering wheels that retain the airbag.
NLSP is offline   Reply With Quote
Old 04-22-2015, 08:51 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You wont get the quick release if you want the air bag.
Then again im not against driving with a helmet and atleast 4 point harness...
Old 04-22-2015, 08:57 PM   #10
ryoma
ryoma's Avatar
isn't the DAMD wheel the same size as the OEM wheel? I thought OEM was 360mm while DAMD is listed at 358. I'm looking for the smallest one I can find that will keep the airbag. is Cusco the only one at 350mm? I really like the TRD one, but it is the same size as OEM so it's kind of pointless lol.
Old 04-22-2015, 09:01 PM   #11
8R6
8R6's Avatar
Drives: FRS
when you get pulled over, good luck explaining to a cop why you're missing a steering wheel airbag. lol
8R6 is offline   Reply With Quote
Old 04-22-2015, 10:31 PM   #12
NLSP
NLSP's Avatar
Nope, DAMD is definitely smaller.
OEM: 365
TRD: 360
DAMD & Prova: 358
Cusco: 350
I didn't like the shape of the Cusco, I don't like suede/Alcantara that the Prova is made with, and the TRD doesn't have any grooves to conform with your hand/thumbs, so it was DAMD for me. I also have a DAMD wheel in another car, so I knew it was going to be a quality piece.
Old 05-22-2020, 05:15 PM   #13
SimGod
Drives: Toyota 86
After market q/r steering wheel
Hello! I have a 2017 Toyota 86 base automatic. Does anybody know if you can install an aftermarket steering wheel with quick release (nrg, sparco ) and keep functioning racing paddles?
SimGod is offline   Reply With Quote
Old 05-22-2020, 08:41 PM   #14
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Name+State+Post=
https://www.ft86club.com/forums/showthread.php?t=136856
DIY Aftermarket Steering Wheel Install kylefrs DIY (Do-It-Yourself) Guides 66 12-11-2022 12:33 AM
Aftermarket steering wheel.. _F-R-S_ Cosmetic Modification (Interior/Exterior/Lighting) 164 04-20-2018 05:29 PM
Aftermarket Steering Wheel for AT Transmission chiefshayan Cosmetic Modification (Interior/Exterior/Lighting) 3 02-21-2014 06:49 AM
Aftermarket steering wheel with CC? Yamajee Cosmetic Modification (Interior/Exterior/Lighting) 11 02-16-2014 06:05 AM
Aftermarket steering wheel HELP! Juurian Cosmetic Modification (Interior/Exterior/Lighting) 0 06-03-2013 11:47 PM
