Old 06-01-2015, 10:30 PM   #1
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Installed Coils and Toe is really bad
Hey guys,
I wanted to get your guys opinion on this.
So today I installed Tein street flex with SPC lower control arms. When I was done, I took my car for a test drive. My car was going all over the road. When I got home, I noticed that the tow in the rear of the car was really bad. Any thoughts on this? I have lowered many vehicles and my 86 is the first one to ever to be this bad after install.
Sugi is offline   Reply With Quote
Old 06-01-2015, 10:49 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Get an alignment.
cnk is offline   Reply With Quote
Old 06-01-2015, 11:05 PM   #3
ryoma
ryoma's Avatar
always get an alignment after swapping out suspension parts. try to avoid long distance driving so that you don't ruin your tires due to the out of spec toe.
Old 06-01-2015, 11:43 PM   #4
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
I'm in the same boat. Street Flex and SPC Arms too. Alignment will solve everything but I can afford to wait until my wheels come in since my commute is relatively not far.
DuMa is offline   Reply With Quote
Old 06-01-2015, 11:49 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Driving any vehicle while misaligned is a recipe for trouble. Lower speeds are ok but keep it off of the highway, please.
Old 06-01-2015, 11:58 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by cnk View Post
Get an alignment.
to ya motha.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Ultramaroon (06-02-2015)
Old 06-02-2015, 12:36 AM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
to ya motha.
Mom says get an alinment too, apparently.
Old 06-02-2015, 12:58 AM   #8
Sugi
Sugi's Avatar
Because I just installed today, do I need to worry about doing this again if I decide to lower the vehicle further?
Old 06-02-2015, 01:08 AM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Get an alignment first. Then we'll talk.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
jimmillion (06-02-2015), Ultramaroon (06-02-2015), YangerD (06-02-2015)
Old 06-02-2015, 02:07 AM   #10
ryoma
ryoma's Avatar
yes you will. every time you adjust the height of your car through your coilovers, it adjusts your whole suspension. however, I would say drive your car locally for like a few days before getting an alignment. give your springs time to settle in. you will find that your car will be slightly lower than when you first installed your coilovers.
Old 06-02-2015, 04:46 PM   #11
Sugi
Sugi's Avatar
So in other words, I need to get the suspension dialed in on how low I want my vehicle to be and can't adjust it without spending another $80?
Old 06-02-2015, 04:56 PM   #12
mav1178
mav1178's Avatar
What exactly is the issue here? You need an alignment to fix the rear toe...
As for whether or not you want to adjust further, you just have to ask yourself how much are your tires worth.
-alex
Old 06-02-2015, 04:59 PM   #13
cnk
It's pretty simple. Set your ride height the way you want it. Drive for a few days to let the springs settle. Go get an alignment. If you change your ride height, you'll need to get another alignment.
Old 06-02-2015, 04:59 PM   #14
ryoma
ryoma's Avatar
Work out a deal with your alignment man. I've been going to the same guy for the last 5 years for all off my cars. He has a 3k mile warranty where he'll recheck the alignment and set it back to the initial specs for free.
Sent from my VS980 4G using Tapatalk
The Following User Says Thank You to ryoma For This Useful Post:
Sugi (06-02-2015)
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Scion installed vs dealer installed fog lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 10 02-16-2014 12:55 PM
St coils vs BC BR? motorsports3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-26-2013 06:01 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 12:09 AM
