Old 06-01-2015, 08:22 PM   #1
Mitchymanboy
Mitchymanboy's Avatar
Drives: Scion FR-S
Red face Whoops Wrong Oil
Well I just read that the FR-S uses 0w-20 full synthetic but I've been putting 0w-30 (Mobil 1) in it . I put about 2-3 miles on the car a day but every month or so I drive a couple hundred Highway miles.
So... should I change it?? (only been 500 miles or about 3 months)
I'm going to be going to college in eastern KY so expecting mild summer/winter
BTW I seem to be getting 40mpg Hwy, or at least that's what the car tells me
Mitchymanboy is offline   Reply With Quote
Old 06-01-2015, 08:24 PM   #2
swarb
The Following User Says Thank You to swarb For This Useful Post:
Teseo (06-01-2015)
Old 06-01-2015, 08:40 PM   #3
DarkSunrise
DarkSunrise's Avatar
As long as it's a synthetic, 0w30 is fine. The manual recommends 0w20, but states you can use a heavier weight oil in severe conditions.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
JohnJuan (06-02-2015)
Old 06-01-2015, 11:24 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^this^^ No sweat.
Now, your 2-3 miles/day? No no no... You are killing your engine by never getting it up to operating temp. Most of the wear occurs when it's cold because the parts don't quite fit. Also water, it accumulates in the oil and never has a chance to evaporate.
If you're regularly driving such short distances, IMHO, break out the bicycle. It better for both you and the car.
cdrazic93 (06-24-2015)
Old 06-01-2015, 11:46 PM   #5
D_Thissen
D_Thissen's Avatar
Op. Nice pc12
Old 06-02-2015, 12:40 AM   #6
humfrz
Don't worry about it ...... it will be OK. However, I would suggest you switch to 0w20 at your next oil change.
Yep, as mentioned above, the short trips are hard on an engine ..... but, it won't kill it!
I would suggest that you NOT change your life style to fit the engine of a car ..... the damn thing exists to serve YOU .....
humfrz
Old 06-02-2015, 12:42 AM   #7
Ultramaroon
not playing cards
humfrz
Oh, ok. Admittedly a bit hyperbolic.
humfrz (06-02-2015)
Old 06-02-2015, 01:31 AM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
2-3 miles? Make sure to warm it up.
Packofcrows is offline   Reply With Quote
Old 06-02-2015, 03:20 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
I have 0W40 in mine. If it gets at or close to freezing in winter, go back to 20 weight. It's fine. In warmer countries the OEM oil is 5W30 BTW.
Old 06-03-2015, 05:12 PM   #10
LostSalad
Drives: Toyota 86 - Charcoal Grey
The Subaru mech I spoke to said they recommend 5w30 for all their cars including the BRZ because the climate is just too damn hot for 0w20. The Toyota mech said that they recommend 0w20... So at the end of the day, I bought the Toyota oil.. because they are the ones who will be servicing my car *shrug*
LostSalad is offline   Reply With Quote
The Following User Says Thank You to LostSalad For This Useful Post:
nivek111070 (06-26-2015)
Old 06-03-2015, 05:18 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Subaru: several models w/ turbo engines, harsher on oil
Toyota: not so much
The recommendation is valid, depending on the experience of the mechanic.
At the end of the day, as long as you are within the oil guidelines and ambient temp range(s), you can run whatever weight you want and it will be fine. The only thing suffering is your gas mileage.
-alex
Old 06-03-2015, 11:18 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I've already stopped using 0w-20 entirely and have switched to 0w-30 exclusively for the FRS. Winter/Summer don't care.
YMMV (literally)
PRO86 | WTCC | STL
The Following 4 Users Say Thank You to rice_classic For This Useful Post:
Dream20b (06-24-2015), Guff (06-17-2015), Jar (06-17-2015), mav1178 (06-17-2015)
Old 06-17-2015, 12:41 AM   #13
Cal3000
Drives: Panda FR-S
I have 90,000 miles on my car; boosted and I beat on it everyday. I use only Mobile1 0W-30. It has treated me well. OP, you are fine.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 06-17-2015, 08:14 PM   #14
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Originally Posted by rice_classic View Post
YMMV (literally)
This didn't get enough love.
Jar is offline   Reply With Quote
whoops Model Citizen Other Vehicles & General Automotive Discussions 19 04-27-2015 08:13 PM
Whoops - remove, please bluesman Wheels and Tires 0 06-03-2014 08:25 AM
Something wrong with my DRL's? FRSHunter Scion FR-S / Toyota 86 GT86 General Forum 3 03-26-2014 07:46 PM
This must be wrong... Ongor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-23-2014 11:29 AM
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
