Drives: None
Is installing an oil cooler dificult?
So I recently ordered an Avo oil cooler with the thermostat for my car and I was wondering how long it takes to install one and if it's difficult to install or not?
Drives: 2013 FRS
I installed my first oil cooler recently. Is it difficult? No. How long it takes will really depend on how familiar with your car you are. I had never removed my front bumper up to that point... but now that Ive done it a couple times I can have that thing on/off in a flash.
All in all you will most likely spend a couple hours start to finish. Pro tip: Make sure you torque everything down properly. Make sure your fittings are on straight and do not over torque em, as you can misalign things causing yourself leaks.
A zen master once told me "Do the opposite of everything I say", so I didn't.
Drives: (formerly) 2013 Raven FR-S
Haven't done it to this car in particular, but to add the great suggestions Juggles already said, be sure to check all the lines after you start the car for any leaks. Then drive around the block a bit without your front bumper cover, pull back into the driveway/garage, and re-check all your lines before re-installing your front bumper cover.
Drives: '13 UM86
Not really - just time consuming. It is difficult if you don't have the proper tools.
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
I did my Perrin last week. The hardest part was removing the front bumper and finding a 27mm socket thin enough to tighten the oil filter bolt. Other than that, it was just time-consuming, but not too hard.
2022 BRZ Build 2013 FR-S Build |
Drives: Subaru BRZ
dunno how the avo kit looks but make sure the lines aren't rubbing up against anything sharp. after the initial install, test drive, and then recheck i would wait a few weeks to a month and then recheck everything again.
2014 WRB BRZ
Its not hard, just make sure the fittings are super tight. I did mine and it leaked out of several. Other then that its pretty easy. If you never taken the front bumper off, that can be a PITA
Drives: None
#10 |
I would do a fresh change. So empty old oil. Install cooler and then fill with fresh oil
2013 Series 10 FRS #553
| Installing Resonator? | l0aded | Engine, Exhaust, Transmission | 36 | 07-14-2022 10:06 PM |
| Need help installing some coils | tysoNgwaNg | Northern California | 14 | 03-24-2014 08:20 PM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
| Installing a hood for the fr-s? | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 08-16-2013 11:06 AM |
| need help installing this | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-14-2013 01:17 PM |
