Old 06-14-2014, 11:16 PM   #1
kcco-whiteout
Drives: Pony
Raceseng Camber adj top mounts issue
Doing the last touches on my suspension this morning and when installing my new top mounts everything went smoothly. Until it was time to torque my camber bolts. The first one went fine. But when I was torquing the next one to the recommended 13ftlbs the bolt broke. My heart jumped into my throat and I almost cried. I triple checked the torque wrench before I even put it on the bolt and quadruple checked after it broke and got my roommate to check just in case I was going crazy. Nope I followed the instructions to the letter. I pulled the broken bolt out and it wasn't crossed or anything. Maybe I got a defective bolt? I went to Lowe's and found the closest match and everything works. Reinstalled and was on the verge of heart failure when I was torquing them this time. All went well though. Has this happened to anyone else? Can I get a new bolt from Raceseng without having to take everything apart again or would I have to send it in? I'm assuming my replacement bolt that I installed should work well but I'd rather have the one I'm supposed to. I've only installed one side so far and I'm about to install the other. What should I do? Here are some pics. Name:  uploadfromtaptalk1402801816000.jpg
Size:  71.1 KB After the bolt broke.
Size:  71.1 KBName:  uploadfromtaptalk1402801816000.jpg
Size:  71.1 KB And the offending bolt itself.
Sent from my HTC One
kcco-whiteout is offline   Reply With Quote
Old 06-15-2014, 07:04 AM   #2
xwd
A replacement bolt from anywhere should work. What kind of toque wrench were you using? Ones going up to like 100 Ft-lbs aren't very accurate at 14.
The Following User Says Thank You to xwd For This Useful Post:
Model Citizen (06-15-2014)
Old 06-15-2014, 08:31 AM   #3
Model Citizen
Lacking brains
Drives: frz
That said raceseng service is top notch. I had emailed him with an issue a couple months back, had tracking for what I needed by the first hour or so of the business day.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-15-2014, 09:01 AM   #4
Malt
Drives: 2015 WRX
Just give @Raceseng a call or email and let them know what happened. They will take care of you.
Malt is offline   Reply With Quote
Old 06-15-2014, 12:45 PM   #5
Raceseng
Raceseng's Avatar
Originally Posted by kcco-whiteout View Post
Doing the last touches on my suspension this morning and when installing my new top mounts everything went smoothly. Until it was time to torque my camber bolts. The first one went fine. But when I was torquing the next one to the recommended 13ftlbs the bolt broke. My heart jumped into my throat and I almost cried. I triple checked the torque wrench before I even put it on the bolt and quadruple checked after it broke and got my roommate to check just in case I was going crazy. Nope I followed the instructions to the letter. I pulled the broken bolt out and it wasn't crossed or anything. Maybe I got a defective bolt? I went to Lowe's and found the closest match and everything works. Reinstalled and was on the verge of heart failure when I was torquing them this time. All went well though. Has this happened to anyone else? Can I get a new bolt from Raceseng without having to take everything apart again or would I have to send it in? I'm assuming my replacement bolt that I installed should work well but I'd rather have the one I'm supposed to. I've only installed one side so far and I'm about to install the other. What should I do? Here are some pics. Attachment 82067 After the bolt broke.
Attachment 82067Attachment 82067 And the offending bolt itself.
Hey, sorry about the hardware issue! I wish I could manufacture our hardware too but we don't have the equipment for that. It sounds like the socket head screw sheared just under the head.
I will gladly replace all the socket head cap screws, please email me - jarrett@raceseng.com with your name and address.
Jarrett Seng
Raceseng | Owner
610.336.0206
Raceseng is offline   Reply With Quote
The Following 5 Users Say Thank You to Raceseng For This Useful Post:
CSG Mike (06-15-2014), F1point4 (06-16-2014), FT-86 SpeedFactory (06-16-2014), Jive Turkey (06-16-2014), jonbonazza (06-16-2014)
Old 06-15-2014, 01:17 PM   #6
kcco-whiteout
Drives: Pony
Hey thanks Jarrett. You guys have amazing customer service from what I've heard and this just solidifies it for me. I sent you an email. I finished installing everything else with no issues at all. Great product btw. Everything was simple and easy to install. I will definitely buy from you all again.
Old 06-15-2014, 01:35 PM   #7
Raceseng
Raceseng's Avatar
Responded, the replacements or spares will ship out Monday! Thanks for the compliments and trusting us!
Jarrett Seng
Raceseng | Owner
610.336.0206
Old 06-15-2014, 05:24 PM   #8
Easy issue, easy fix.
This is why we love the @Raceseng stuff.
OICU812 (06-15-2014)
Old 06-16-2014, 12:27 AM   #9
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
This just reinforces my decision to buy these when I'm ready to pull the trigger on front plates.
Sent from my SM-G900V using Tapatalk
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following 2 Users Say Thank You to Turkish For This Useful Post:
CSG Mike (06-16-2014), Raceseng (06-16-2014)
Old 06-16-2014, 12:46 AM   #10
kcco-whiteout
Drives: Pony
Definitely worth it. I installed them along with the spl lcas to go with my st coilovers, got my ride height all sorted out and got my alignment today. So worth it. Handles great. Thanks to @CSG Mike for helping me out with some decisions.
The Following 2 Users Say Thank You to kcco-whiteout For This Useful Post:
Old 06-16-2014, 01:01 AM   #11
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
This thread just sold me on the raceseng plates for sure. The fact that counter space loves them was part one, epic customer service sealed the deal.
jebuwh is offline   Reply With Quote
The Following 2 Users Say Thank You to jebuwh For This Useful Post:
Old 06-16-2014, 01:43 AM   #12
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Good thing you were able to extract it without issue. Otherwise it would have been a bigger ordeal.
Old 06-16-2014, 02:01 AM   #13
Turkish
Serial Cone Killer
Turkish's Avatar
Agreed.
... his name is...
C'THULHU
The Following User Says Thank You to Turkish For This Useful Post:
Old 06-16-2014, 02:15 AM   #14
Let us know when you guys want to order
jebuwh (06-16-2014), Raceseng (06-16-2014)
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 10:32 AM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 05:34 PM
Testing Waters: FS KWV3s with Ground control camber plates and robispec rear mounts YDNA Brakes, Suspension, Chassis 0 01-25-2014 02:34 AM
Raceseng | CasCam - Caster + Camber Plate Black Friday Sale Raceseng Brakes, Suspension, Chassis 0 11-30-2013 11:09 AM
Color options Camber Plates, Stress Bar, & Shock Mounts GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-26-2013 01:08 PM
