Old 05-20-2015, 01:15 PM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
sensors offset in AIM
I don't know if anyone ever noticed but when i start the car and it is cold, my aat, iat, ect and oil temp should pretty much read all the same thing but it seems like they are like 10 degC + of difference.
I talked about it to the guys at AIM and they suggested to give them solid data so they could change their codes in the software to get more accurate readings.
Anyone has an other device along with their AIM to compare the 2 values, both when cold and when at operating temp?
car is in repair as we speak so i can't take any readings but i'll try to compare with my ecutek, if anyone has other devices, the more data we have the better we can have them correct the ecu reading for our cars.
thanks
puma is offline   Reply With Quote
Old 05-20-2015, 02:23 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
For the oil temp, what are you comparing the AIM readings to? Is the AIM sensing from the ECU or a standalone sensor?
JDKane527 is offline   Reply With Quote
Old 05-20-2015, 02:59 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Unless you've parked it in a temperature-controlled room for enough time for the core of the engine block to be the same temp as the ambient temperature, they will all be different.
-alex
Old 05-20-2015, 05:31 PM   #4
puma
crew chief
puma's Avatar
all the sensors i am talking about are OEM sensors.
yeah car is a race car so it has been sitting in a garage for all winter when i installed the MXL an it always is in garage.
Old 05-21-2015, 08:36 AM   #5
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
By OEM I'm assuming you are pulling the data off the CAN or OBDII Bus?
-mike
AZP Installs is offline   Reply With Quote
Old 05-21-2015, 01:10 PM   #6
puma
crew chief
puma's Avatar
yes sensors pulled from the CAN, like a regular AIM installation, either with soloDL through obd2 or MXL by hardwiring into a CAN wire.
Old 05-21-2015, 05:14 PM   #7
sw20kosh
Drives: 2013 Black FR-S
Yes coolant and IAT are reading 10 deg lower than they should. There is a software patch for this.
@mkivsoopra
Old 05-21-2015, 05:19 PM   #8
mkivsoopra
@mkivsoopra
here! http://www.ft86club.com/forums/showt...t=70030&page=4
mkivsoopra is offline   Reply With Quote
O2 sensors FirestormFRS Engine, Exhaust, Transmission 1 12-29-2014 08:38 PM
WTB - TPMS sensors drftxx Wheels and Tires 1 02-25-2014 09:36 PM
TPS Sensors Brahsbrah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-18-2013 11:03 PM
Parking Sensors? Skippman Electronics | Audio | NAV | Infotainment 4 07-12-2013 02:05 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
